Is it possible to update an esp8266 using HTTPUpdate with a certificate or a Hash key check before update?
Have you checked their example ➜
i changed the libraries for ESP8266 but i got this error:
Compilation error: 'class WiFiClient' has no member named 'setCACert'
this is the code:
httpUpdateSecure.ino
Created on: 16.10.2018 as an adaptation of the ESP8266 version of httpUpdate.ino
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <ESP8266HTTPClient.h>
#include <ESP8266httpUpdate.h>
#include <time.h>
ESP8266WiFiMulti WiFiMulti;
// Set time via NTP, as required for x.509 validation
void setClock() {
configTime(0, 0, "pool.ntp.org", "time.nist.gov"); // UTC
Serial.print(F("Waiting for NTP time sync: "));
time_t now = time(nullptr);
while (now < 8 * 3600 * 2) {
yield();
Serial.print(F("."));
Serial.println(F(""));
struct tm timeinfo;
gmtime_r(&now, &timeinfo);
Serial.print(F("Current time: "));
Serial.print(asctime(&timeinfo));
* This is lets-encrypt-x3-cross-signed.pem
const char* rootCACertificate = \
"-----BEGIN CERTIFICATE-----\n" \
"MIIEkjCCA3qgAwIBAgIQCgFBQgAAAVOFc2oLheynCDANBgkqhkiG9w0BAQsFADA/\n" \
"MSQwIgYDVQQKExtEaWdpdGFsIFNpZ25hdHVyZSBUcnVzdCBDby4xFzAVBgNVBAMT\n" \
"DkRTVCBSb290IENBIFgzMB4XDTE2MDMxNzE2NDA0NloXDTIxMDMxNzE2NDA0Nlow\n" \
"SjELMAkGA1UEBhMCVVMxFjAUBgNVBAoTDUxldCdzIEVuY3J5cHQxIzAhBgNVBAMT\n" \
"GkxldCdzIEVuY3J5cHQgQXV0aG9yaXR5IFgzMIIBIjANBgkqhkiG9w0BAQEFAAOC\n" \
"AQ8AMIIBCgKCAQEAnNMM8FrlLke3cl03g7NoYzDq1zUmGSXhvb418XCSL7e4S0EF\n" \
"q6meNQhY7LEqxGiHC6PjdeTm86dicbp5gWAf15Gan/PQeGdxyGkOlZHP/uaZ6WA8\n" \
"SMx+yk13EiSdRxta67nsHjcAHJyse6cF6s5K671B5TaYucv9bTyWaN8jKkKQDIZ0\n" \
"Z8h/pZq4UmEUEz9l6YKHy9v6Dlb2honzhT+Xhq+w3Brvaw2VFn3EK6BlspkENnWA\n" \
"a6xK8xuQSXgvopZPKiAlKQTGdMDQMc2PMTiVFrqoM7hD8bEfwzB/onkxEz0tNvjj\n" \
"/PIzark5McWvxI0NHWQWM6r6hCm21AvA2H3DkwIDAQABo4IBfTCCAXkwEgYDVR0T\n" \
"AQH/BAgwBgEB/wIBADAOBgNVHQ8BAf8EBAMCAYYwfwYIKwYBBQUHAQEEczBxMDIG\n" \
"CCsGAQUFBzABhiZodHRwOi8vaXNyZy50cnVzdGlkLm9jc3AuaWRlbnRydXN0LmNv\n" \
"bTA7BggrBgEFBQcwAoYvaHR0cDovL2FwcHMuaWRlbnRydXN0LmNvbS9yb290cy9k\n" \
"c3Ryb290Y2F4My5wN2MwHwYDVR0jBBgwFoAUxKexpHsscfrb4UuQdf/EFWCFiRAw\n" \
"VAYDVR0gBE0wSzAIBgZngQwBAgEwPwYLKwYBBAGC3xMBAQEwMDAuBggrBgEFBQcC\n" \
"ARYiaHR0cDovL2Nwcy5yb290LXgxLmxldHNlbmNyeXB0Lm9yZzA8BgNVHR8ENTAz\n" \
"MDGgL6AthitodHRwOi8vY3JsLmlkZW50cnVzdC5jb20vRFNUUk9PVENBWDNDUkwu\n" \
"Y3JsMB0GA1UdDgQWBBSoSmpjBH3duubRObemRWXv86jsoTANBgkqhkiG9w0BAQsF\n" \
"AAOCAQEA3TPXEfNjWDjdGBX7CVW+dla5cEilaUcne8IkCJLxWh9KEik3JHRRHGJo\n" \
"uM2VcGfl96S8TihRzZvoroed6ti6WqEBmtzw3Wodatg+VyOeph4EYpr/1wXKtx8/\n" \
"wApIvJSwtmVi4MFU5aMqrSDE6ea73Mj2tcMyo5jMd6jmeWUHK8so/joWUoHOUgwu\n" \
"X4Po1QYz+3dszkDqMp4fklxBwXRsW10KXzPMTZ+sOPAveyxindmjkW8lGy+QsRlG\n" \
"PfZ+G6Z6h7mjem0Y+iWlkYcV4PIWL1iwBi8saCbGS5jN2p8M+X+Q7UNKEkROb3N6\n" \
"KOqkqm57TH2H3eDJAkSnh6/DNFu0Qg==\n" \
"-----END CERTIFICATE-----\n";
// Serial.setDebugOutput(true);
for (uint8_t t = 4; t > 0; t--) {
Serial.printf("[SETUP] WAIT %d...\n", t);
Serial.flush();
WiFi.mode(WIFI_STA);
WiFiMulti.addAP("SSID", "PASSWORD");
// wait for WiFi connection
if ((WiFiMulti.run() == WL_CONNECTED)) {
setClock();
WiFiClientSecure client;
client.setCACert(rootCACertificate);
// Reading data over SSL may be slow, use an adequate timeout
client.setTimeout(12000 / 1000); // timeout argument is defined in seconds for setTimeout
// The line below is optional. It can be used to blink the LED on the board during flashing
// The LED will be on during download of one buffer of data from the network. The LED will
// be off during writing that buffer to flash
// On a good connection the LED should flash regularly. On a bad connection the LED will be
// on much longer than it will be off. Other pins than LED_BUILTIN may be used. The second
// value is used to put the LED on. If the LED is on with HIGH, that value should be passed
// httpUpdate.setLedPin(LED_BUILTIN, HIGH);
t_httpUpdate_return ret = httpUpdate.update(client, "https://server/file.bin", "", [](HTTPClient *client) {
client->setAuthorization("test", "password");
// Or:
//t_httpUpdate_return ret = httpUpdate.update(client, "server", 443, "/file.bin");
switch (ret) {
case HTTP_UPDATE_FAILED:
Serial.printf("HTTP_UPDATE_FAILED Error (%d): %s\n", httpUpdate.getLastError(), httpUpdate.getLastErrorString().c_str());
case HTTP_UPDATE_NO_UPDATES:
Serial.println("HTTP_UPDATE_NO_UPDATES");
case HTTP_UPDATE_OK:
Serial.println("HTTP_UPDATE_OK");
I guess you don't want to do that then... have you tried with the library they used? the comment at the top
seemed to indicate it was meant for ESP8266
yes i tried that with its own libraries but it didnt compile.
OK... this seemed part of the HTTPUpdate library.. I guess it's broken then
how about this one? do you think this works ?
and this is a combination of HTTPUpdate and HTTPRequest
#include <time.h>
#ifndef APSSID
#define APSSID "<YOUR-SSID>"
#define APPSK "<YOUR-PASSWD>"
#endif
time_t setClock() {
configTime(2*3600, 0, "pool.ntp.org", "time.nist.gov");
Serial.print("Waiting for NTP time sync: ");
Serial.print(".");
Serial.println("");
struct tm timeinfo;
Serial.print("Current time: ");
return now;
void update_started() {
Serial.println("CALLBACK: HTTP update process started");
void update_finished() {
Serial.println("CALLBACK: HTTP update process finished");
void update_progress(int cur, int total) {
Serial.printf("CALLBACK: HTTP update process at %d of %d bytes...\n", cur, total);
void update_error(int err) {
Serial.printf("CALLBACK: HTTP update fatal error code %d\n", err);
static const char serverCACert[] PROGMEM = R"EOF(
MIIDGzCCAgOgAwIBAgIUWd2CIejZK0uuqLPUDTUkA20SyAAwDQYJKoZIhvcNAQEL
BQAwHTEbMBkGA1UEAwwSc2VydmVyb3RhLmRkbnMubmV0MB4XDTIxMDkzMDEyMjkx
MFoXDTIzMDkzMDEyMjkxMFowHTEbMBkGA1UEAwwSc2VydmVyb3RhLmRkbnMubmV0
MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAxXtdGLH6IZKnpJYCyyI9
PWN6dQe4wM0J85lqF+omjxmHCY4WQfON6PwIxlhnDDGC4pj/2m2wFkIpg1sDyMmS
Ow8Q0c7Zu3nqDk5gptKWtkjQdmOlsa48jAX49fwvb6Fwyh+Hz94lLuCTQi59LG2S
UPuubXh74ct1pKnc8pwgtIuClSSbgcLCGkhAnLbjTJaet4UemgVcUcorlmqwDKbd
VQR+5DL6biVxy+cLJcwKqH93xrj9hh1I4ktWSBpM/xInlGnA1Fa0qtGrM6m+d3uq
E/GL6MpM0kIvTyxyFVk+LlProQS8zNyRU1KAw51EcT5qcj6FkVMVpSodyARoJPwn
BwIDAQABo1MwUTAdBgNVHQ4EFgQUY6S5QEqFZe7UTVQLAuet07qsW6MwHwYDVR0j
BBgwFoAUY6S5QEqFZe7UTVQLAuet07qsW6MwDwYDVR0TAQH/BAUwAwEB/zANBgkq
hkiG9w0BAQsFAAOCAQEAmxHExHoWclbgdhsIenSyb2wihbC7+QO69dAfQPwJOEQ9
9Lb4h6nmJzuHD+ohFsnNDm3cnKadG7F7to7/LdeG4g5qBNzdMVolsgMTMQ0wyFBx
iTxKPh2FGsGvzftJoYLNXAYXDKtrwK7cxn+HOQOqCw7Q2clMRljva42GQJytDsOx
7F6pVNDnDzo2H1Sni7WzwzIQGb06dUinPY4AhunYRaasbWAU4a4K35x2c5IqCrMW
5TYYCt2KMOaTNLbd0Lh9/ImeJnImAVGN8DivXbtNfhrj+Pl8McHnUztUMkcyHMNR
dVRh0YwsiXtZcu+RWatZB2eJQZJyZx04pIAwgIdhBA==
)EOF";
#define FIRMWARE_VERSION "0.1"
Serial.flush();
WiFiMulti.addAP(APSSID, APPSK);
Serial.print(F("Firmware version "));
Serial.println(FIRMWARE_VERSION);
const char* updateServer = "serverota.ddns.net";
const int updateServerPort = 3443;
BearSSL::WiFiClientSecure client;
bool mfln = client.probeMaxFragmentLength(updateServer, updateServerPort, 1024); // server must be the same as in ESPhttpUpdate.update()
Serial.printf("MFLN supported: %s\n", mfln ? "yes" : "no");
if (mfln) {
client.setBufferSizes(1024, 1024);
// client.allowSelfSignedCerts();
BearSSL::X509List x509(serverCACert);
client.setTrustAnchors(&x509);
setClock();
ESPhttpUpdate.setLedPin(LED_BUILTIN, LOW);
// Add optional callback notifiers
ESPhttpUpdate.onStart(update_started);
ESPhttpUpdate.onEnd(update_finished);
ESPhttpUpdate.onProgress(update_progress);
ESPhttpUpdate.onError(update_error);
ESPhttpUpdate.rebootOnUpdate(false); // remove automatic update
Serial.println(F("Update start now!"));
t_httpUpdate_return ret = ESPhttpUpdate.update(client, "https://"+String(updateServer)+":"+String(updateServerPort)+"/update", FIRMWARE_VERSION);
switch (ret) {
Serial.printf("HTTP_UPDATE_FAILD Error (%d): %s\n", ESPhttpUpdate.getLastError(), ESPhttpUpdate.getLastErrorString().c_str());
Serial.println(F("Retry in 10secs!"));
delay(10000); // Wait 10secs
Serial.println("Your code is up to date!");
delay(1000); // Wait a second and restart
ESP.restart();
Have you tried?
i will try to test it but before that i want to generate a Hash key instead of Certificate.
now i want to change this :
)EOF";
to this :
static const char serverCACert[] = sha1("LlProQS8zNyRU1KAw51EcT5qcj6FkVMVpSodyARoJPwn");
but i got this error :
Compilation error: initializer fails to determine size of 'serverCACert'
The sha1 function calls happens at run time so the compiler cannot decide how large the array needs to be and it’s not a suitable way to fill up an array
Which sha1() library are you using ? What does it return?
If you think that’s the way to go, write a small piece of code where you print out from the setup the result of the sha1 call and then copy/paste that in the real code
(Why don’t you use the certificate?)
this is the Hash code part :
simple demo to show sha1 calculation
#include <Arduino.h>
#include <Hash.h>
// usage as String
Serial.print("SHA1:");
Serial.println(sha1("LlProQS8zNyRU1KAw51EcT5qcj6FkVMVpSodyARoJPwn"));
the result is this :
SHA1:e16c2075b407328ca39679387ff8080e8fa441cd
It encrypts "LlProQS8zNyRU1KAw51EcT5qcj6FkVMVpSodyARoJPwn" to a SHA1 certificate and then decrypts it on the server side.
Because I want to increase the security of the certificate.
So use
"e16c2075b407328ca39679387ff8080e8fa441cd"
to initialize your char array
how can i put this "e16c2075b407328ca39679387ff8080e8fa441cd" to a char array ?
as i said i got this error :
i searched alot but i still haven't found a solution
You would do
static const char serverCACert[] = "e16c2075b407328ca39679387ff8080e8fa441cd";
But you might want to take a step back and clarify exactly what you are trying to achieve : your web server certificate plays a critical role in securing online communication by authenticating the server and encrypting data. Using strong cryptographic hash functions, like SHA-256 or SHA-3, is essential for maintaining the security and integrity of certificates and data. Using SHA-1 on the client or for cryptographic purposes is not recommended due to its known vulnerabilities.
in more details:
A web server certificate, typically issued in the context of SSL/TLS, serves two primary purposes:
Authentication: It verifies the identity of the web server to ensure that the client is connecting to the legitimate website and not an imposter. This is crucial for preventing man-in-the-middle attacks.
Encryption: It enables the encryption of data transferred between the client (e.g., a web browser) and the server. This ensures that the data transmitted, such as login credentials or sensitive information, remains confidential and secure during transit.
Web server certificates use a cryptographic hash function to ensure their integrity and to create a unique fingerprint.
SHA-1 (Secure Hash Algorithm 1) was once a commonly used hash function for certificates, but it is no longer considered secure due to vulnerabilities that have been discovered over time.
Modern security standards recommend using stronger hash functions like SHA-256 or SHA-3 to protect the certificate's integrity (so basically SHA-1 is considered deprecated and weak in the context of cryptography).
➜ so the question is really what are you trying to protect ? (Define your security posture).
