would anyone want to help and write a program for a high voltage programmer that will work on the board provided in the attachment? I made this board based on the work from Kai Bader, and the sketch included is an example based on the work of Paul Willoughby.
Reward is either 5 printed circuit boards made by Elecrow or one fully populated and tested board made by Elecrow based on this schematic.
Looking forward to your replies,
Erik
Arduino_ATtiny_unbrick_HVprogrammer.ino (4.49 KB)
isp_hvp_shield_Rev_2.0-V2.pdf (37.8 KB)
So, you're making something like this?
johnwasser:
HV Rescue Shield 2 | MightyOhm
Similar but with a difference: my project is a Arduino shield too, but with 5 sockets. The full range of ATtiny (85/45/25/15/13: 8pin, 84/44/24:14pin, 26/261/461/861: 20pin, 2313/4313: 20pin too but different pinout, and the ATmega328: 28pin.
It is based on a project by Kai Bader, but since he has no time to finish it we agreed I could make a pcb; the programming is nowhere yet so therefor my request.
Rgds,
Erik
The pcb layout is not final: any changes required by software can be implemented. For example I had provided MISO, MOSI and SCK to be interconnected. If however other pins are required for example for SDI, SII, SDO and RST then the hardware can be changed.
