How to set ATTINY44 chip, PB3 (pin4) 'Reset' pin as I/O ?
I am making a program for Attiny44 naked IC that Im programming with Arduino UNO R3 as ICSP using AtTiniCore.
Im actually making use of Proteus simulator to test my program. And I discovered a very big inconvenience on this chip. PB3 (pin4) 'Reset' pin, I can not set it as I/O, unless I am setting a fuse specific for it, and that is not allowing me to program the chip in ICSP mode anymore, from what I understood.
So in proteus I had to set this option, to see that pin operational.
:warning: Important Warning
Disabling the RESET pin turns it into a general-purpose I/O (PB3),
but you will no longer be able to reprogram the chip
using ISP unless you have a High Voltage Programmer (HVP)
What is this (HVP)? and how do I make one? I want details about it.
And what are the risks using it ?
Or...is there another way? I still want to re-use this IC in the future, using Arduino R3 as ICSP; as I usually use it.
I didnt try anything in reality, I ONLY check it in my Proteus simulator and also read some stuff about it.
In my project, I am using exactly 2 buttons (so 2 inputs no mater where they are) and exactly 10 LEDs (so 10 outputs). All of these are consuming the maximum of I/O of this IC.
Thank you.
A high voltage programmer is a programmer that let's you set the fuses of the chip by actually providing 12v+ to the reset pin (instead of just 5v+)
They are not to hard to built, have a look here
I think i used the 2nd sketch sort of, this is what i use
// AVR High-voltage Serial Fuse Reprogrammer
// Adapted from code and design by Paul Willoughby 03/20/2010
// http://www.rickety.us/2010/03/arduino-avr-high-voltage-serial-programmer/
// Fuse Calc:
//   http://www.engbedded.com/fusecalc/
// https://eleccelerator.com/fusecalc/fusecalc.php?chip=attiny13
#define  RST     13    // Output to level shifter for !RESET from transistor
#define  SCI     12    // Target Clock Input
#define  SDO     11    // Target Data Output
#define  SII     10    // Target Instruction Input
#define  SDI      9    // Target Data Input
#define  VCC      8    // Target VCC
#define  HFUSE  0x747C
#define  LFUSE  0x646C
#define  EFUSE  0x666E
// Define ATTiny series signatures
#define  ATTINY13   0x9007  // L: 0x6A, H: 0xFF             8 pin
#define  ATTINY24   0x910B  // L: 0x62, H: 0xDF, E: 0xFF   14 pin
#define  ATTINY25   0x9108  // L: 0x62, H: 0xDF, E: 0xFF    8 pin
#define  ATTINY44   0x9207  // L: 0x62, H: 0xDF, E: 0xFFF  14 pin
#define  ATTINY45   0x9206  // L: 0x62, H: 0xDF, E: 0xFF    8 pin
#define  ATTINY84   0x930C  // L: 0x62, H: 0xDF, E: 0xFFF  14 pin
#define  ATTINY85   0x930B  // L: 0x62, H: 0xDF, E: 0xFF    8 pin
  pinMode(VCC, OUTPUT);
  pinMode(RST, OUTPUT);
  pinMode(SDI, OUTPUT);
  pinMode(SII, OUTPUT);
  pinMode(SCI, OUTPUT);
  pinMode(SDO, OUTPUT);     // Configured as input when in programming mode
  digitalWrite(RST, HIGH);  // Level shifter is inverting, this shuts off 12V
  Serial.println("ATtiny HV Programmer");
  Serial.println("Type 'I' for Fuse Settings");
  Serial.println("Type 'D' For Setting fuses to Default");
  Serial.println("Type 'R' For Setting Reset Disable");
  if (Serial.available()) {
    char c = Serial.read();
    pinMode(SDO, OUTPUT);     // Set SDO to output
    digitalWrite(SDI, LOW);
    digitalWrite(SII, LOW);
    digitalWrite(SDO, LOW);
    digitalWrite(RST, HIGH);  // 12v Off
    digitalWrite(VCC, HIGH);  // Vcc On
    delayMicroseconds(20);
    digitalWrite(RST, LOW);   // 12v On
    delayMicroseconds(10);
    pinMode(SDO, INPUT);      // Set SDO to input
    delayMicroseconds(300);
    unsigned int sig = readSignature();
    Serial.print("Signature is: ");
    Serial.println(sig, HEX);
    Serial.print("Chip : ");
    switch (sig) {
      case ATTINY13:
        Serial.println("ATtiny13");
      case ATTINY24:
        Serial.println("ATtiny24");
      case ATTINY25:
        Serial.println("ATtiny25");
      case ATTINY44:
        Serial.println("ATtiny44");
      case ATTINY45:
        Serial.println("ATtiny45");
      case ATTINY84:
        Serial.println("ATtiny84");
      case ATTINY85:
        Serial.println("ATtiny85");
    if (c == 'D') {
      readFuses(sig);
      if (sig == ATTINY13) {
        writeFuse(LFUSE, 0x6A);
        writeFuse(HFUSE, 0xFF);
      else if (sig == ATTINY24 || sig == ATTINY44 || sig == ATTINY84 ||
               sig == ATTINY25 || sig == ATTINY45 || sig == ATTINY85) {
        writeFuse(LFUSE, 0x62);
        writeFuse(HFUSE, 0xDF);
        writeFuse(EFUSE, 0xFF);
      Serial.println("Fuses Set to Defaults");
      readFuses(sig);
    else if (c == 'R') { // reset disable
      uint32_t fuses = readFuses(sig);
        byte val = (fuses >> 16) & 0xFF; //keep current settings
        writeFuse(LFUSE, val);
        val = (fuses >> 8) & 0xFE; // disable bit 0 = reset disable
        writeFuse(HFUSE, val);  // other bits should be retained
        val = (fuses >> 8) & 0x7F; // disable bit 7 = reset disable
        val = (fuses) & 0xFF;
        writeFuse(EFUSE, val);
      Serial.println("Reset Fuse disabled");
      readFuses(sig);
    else if (c == 'I') {
      readFuses(sig);
    digitalWrite(SCI, LOW);
    digitalWrite(VCC, LOW);    // Vcc Off
    Serial.println("Process Completed");
byte shiftOut (byte val1, byte val2) {
  int inBits = 0;
  //Wait until SDO goes high
  while (!digitalRead(SDO))
  unsigned int dout = (unsigned int) val1 << 2;
  unsigned int iout = (unsigned int) val2 << 2;
  for (int ii = 10; ii >= 0; ii--)  {
    digitalWrite(SDI, !!(dout & (1 << ii)));
    digitalWrite(SII, !!(iout & (1 << ii)));
    inBits <<= 1;         inBits |= digitalRead(SDO);
    digitalWrite(SCI, HIGH);
  return inBits >> 2;
void writeFuse (unsigned int fuse, byte val) {
  shiftOut(0x40, 0x4C);
  shiftOut( val, 0x2C);
  shiftOut(0x00, (byte) (fuse >> 8));
  shiftOut(0x00, (byte) fuse);
uint32_t readFuses (uint16_t sig) {
  byte val;
  uint32_t fuses;
  shiftOut(0x04, 0x4C);  // LFuse
  shiftOut(0x00, 0x68);
  val = shiftOut(0x00, 0x6C);
  fuses = val;
  Serial.print("LFuse ");
  Serial.print(val, HEX);
  shiftOut(0x04, 0x4C);  // HFuse
  shiftOut(0x00, 0x7A);
  val = shiftOut(0x00, 0x7E);
  fuses = fuses << 8;
  fuses |= val;
  Serial.print(", HFuse: ");
  shiftOut(0x04, 0x4C);  // EFuse
  shiftOut(0x00, 0x6A);
  val = shiftOut(0x00, 0x6E);
  fuses = fuses << 8;
  fuses |= val;
  if (sig != ATTINY13) {
    Serial.print(", EFuse: ");
  return fuses;
unsigned int readSignature () {
  unsigned int sig = 0;
  byte val;
  for (int ii = 1; ii < 3; ii++) {
    shiftOut(0x08, 0x4C);
    shiftOut(  ii, 0x0C);
    sig = (sig << 8) + val;
  return sig;
I ended up using a step-up converter to provide the 12v, so it became 1 neat package.
This is a Fuse-bit calculator
Correct, and a HVP allows you to reset that fuse. But if more IO pins is important to you, check for another MCU like the 328P.
Well the reset pin can be used as an analog input with a limited range. The input voltage should never drop below Vcc/2 (with a safe margin) or the AtTiny will reset, but it is not hard to use it as an input pin that way. Just some voltage division will do the trick,
VERY INTERESTING !!! I didnt know this detail.
Can you show me a skematic or explain in words a bit more detailed , that I can simulate it quickly and check how its working?
-And also, how do I read (as an input) this Reset pin in code? If it is not set as I/O? or at least is not seen as one. Hmmm. Very novel to me.
I actually have 10pcs of naked atmega328P ICs (no boards). They are my plan B.
But I want this attiny44 to use because is cute and tiny !!! Haha.
I got 84 and the 85, and according to specs 84 draws slightly less than 85, + it gives me more IO pins freedom.
"cute" ? That's a new dimension to it that never crossed my mind :upside_down_face:
I made this but the simulator is not responsive.
Or my code is not right !!! Because I have no idea what the code should look like. I did it like any other I/O pin, but I guess it needs some special stuff !
and, I managed to make it kind of work .... by using 2 switches and some calibration...at least in the simulator. Im very unsure how it will work in reality. Hmmm.... Very sketchy what I built there... but is a step I suppose.
Oh sorry on an AtTiny44 the RST pin is not connected to the ADC.
Still something else came to mind, since you are only 1 pin short.
2 buttons can share an analog pin.
Just with 3 times the same resistor value. If you add 1 more resistor you may even be able to test for a simultanious press.
VERY INTERESTING IDEA !!!! I like it !
So by the look of it, the entire PORTA (PA0-PA7) are ADC pins (in green). Right?
So how you put it, I should be able to use any one of those pins. Correct?
I actually need 3 buttons to use !!!
It would be awesome to be able to squeeze a 3rd one !
Yes and then read the analog value (i think it's a 10-bit value)
There is of course the option to expand on this idea.
I tend to experiment with the setup using something that has a USB to TTL converter like an UNO so i can read the results of the button press in the Serial monitor and adjust my code to the results.
Topic moved. Please do not post in "Uncategorized"; see the sticky topics in Uncategorized - Arduino Forum.
It seems you are using your pins to drive just one led per pin. You may want to look at Charlieplexing if you want to drive more leds with fewer pins.
