my code done not send commands to smartthings.
How do I fix the wifi will not connect
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <Servo.h>
#define WLAN_SSID " "
#define WLAN_PASS " "
MDNSResponder mdns;
ESP8266WebServer server(80);
Servo myservo;
int pos = 0;
int state = 0;
int prevstate = 0;
int dirc = 0;
int servoPin = 5; //CHANGE TO WHATEVER PIN YOUR USING
String webPage = "";
void setup(void) {
webPage += "
ESP8266 Web Server
Blinds <a href="open">OPEN <a href="close">CLOSE
Serial.println("Blind Startup Sequence");
Serial.print("Connecting to ");
Serial.println(WLAN_SSID);
WiFi.begin(WLAN_SSID, WLAN_PASS);
// Set a static IP (optional)
IPAddress ip(192, 168, 1, 170);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
WiFi.config(ip, gateway, subnet);
// End of set a static IP (optional)
int i = 0;
Serial.print(".");
ESP.wdtFeed();
if (i > 40) // Try 40 times to connect to Wifi
Serial.print("Restarting Wifi"); ESP.reset(); // Reset Wifi stack if more than 40 trys
i++;
// Set a static IP retry (optional)
IPAddress ip(192, 168, 1, 127);
// End of set a static IP retry (optional)
Serial.println("WiFi connected");
Serial.println("IP address: "); Serial.println(WiFi.localIP());
if (mdns.begin("esp8266", WiFi.localIP())) {
Serial.println("MDNS responder started");
server.on("/", {
server.send(200, "text/html", webPage);
server.on("/open", {
Serial.println("HTTP OPEN COMMAND RECEIVED");
dirc = 0; // direction for servo to run
state = 2; // sets current state
server.on("/close", {
Serial.println("HTTP CLOSE COMMAND RECEIVED");
dirc = 180; // direction for servo to run
state = 1; // sets current state
server.begin();
Serial.println("HTTP server started");
void servo_move() {
Serial.println("State Change. Rotating Servo");
if ( dirc == 180) {
myservo.attach(servoPin); // energize servo
delay(50);
for (pos = 0; pos <= 90; pos += 1) { // goes from 0 degrees to 90 degrees in steps of 1 degree CHANGE 90 TO MATCH ANGLE OF TILT DESIRED
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(30); // waits 30ms between each degree to slow rotation speed
delay(50);
myservo.detach(); // movement finished so detach servo to conserve power
else if (dirc == 0) {
delay(50);
for (pos = 90; pos >= 0; pos -= 1) { // goes from 90 degrees to 0 degrees in steps of 1 degree CHANGE 90 TO MIRROR ANGLE OF TILT DESIRED ABOVE
delay(50);
Serial.println("Returning to main loop");
return;
void loop(void) {
if (state != prevstate) {
Serial.println("State change!");
servo_move();
prevstate = state;
server.handleClient();
