HX711 Load Cell Amplifier Issue
Hi everyone,
I am trying to measure mass using a HX711 load cell amplifier connected to a Arduino UNO, however, after attempting to run the program, I get infinity kg output.
I have checked the wires connecting the load cell for correct resistances, and I checked that the amplifier receives power. Is there anything else I might be missing?
Below is the code I am attempting to execute. I followed the Load Cell Amplifier HX711 Breakout Hookup Guide from Sparkfun to do the connections and for the assistance with the code.
#include "HX711.h"
#define calibration_factor 0
#define LOADCELL_DOUT_PIN  3
#define LOADCELL_SCK_PIN  2
HX711 scale;
  Serial.println("HX711 SCALE");
  scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
  scale.set_scale(calibration_factor);
  scale.tare();
  Serial.print(scale.get_units(), 1);
  Serial.print(" kg");
Why don't you try he Sparkfun basic example and see if it works?
I am using their basic example, as far as I know?
You would find the basic example here.
The library readme shows set_scale() used as
loadcell.set_scale(LOADCELL_DIVIDER);
My guess is that you're seeing infinities because you are passing zero to set_scale(). Your reading is then being divided by zero somewhere in the library code.
The sparkfun basic example is located at the link provided by @toddnz.
Use it WITHOUT any modifications
Hi, yes you are totally correct. I removed it and it seems to be giving out actual values now. Thanks!
hi, may i know are you trying the sparkfun basic example coding? because my value is keep on 0. at first i get the value. but then, it keep on to be 0
