HXD8357D 3.5" touch screen SPI libraries?
Hey All,
I'm guessing I should have looked a little harder and probably dropped the ball on this one... I wanted to use a 3.5" touch screen for my lighting project... I picked one up from Adafruit..... Pinout
I wanted to use SPI since I'm just using it for some buttons and menus, nothing overly fancy. I'm having a hard time finding library for it... I think I've found a one or two for 8 bit, but that's more wiring than I really wanted to use. Is there anything out there for this that uses SPI? Are there better options? Am I able to use UTFT or URTouch? Is the ili9481 compatible with the HXD8357D?
Thanks in advance for your input!
Surely Adafruit provides an SPI library. Make the solder-bridge on the pcb to select SPI interface.
It looks as if you have only got a bare resistive panel without a Touch chip.
Adafruit provides a TouchScreen.h library for a bare panel.
UTFT does not support HX8357-D with SPI.
It is easy enough to modify/hack if that is what you want to do.
URTouch.h does not support bare Touch panels.
You could buy a XPT2046 chip. Possibly from Adafruit.
Why do you want to use UTFT or URTouch ?
David.
Hey David,
They do provide some libraries. I was looking to create a gui to control LED lights. There's a couple a libraries I've found, Awind and tft-extension, that have buttons and window control. I was hoping to save some time and effort from having try and code everything from scratch....
If I just use the 8 bit processing, would it work then? Was this a bad choice in screens, is there a better alternative?
I am sure that your display will be fine. It seems unfortunate that it does not come with an XPT2046 Touch controller. In which case you could control everything with SPI.
I do not have your screen. I suggest that you just use the Adafruit library and examples.
Your application should build and run very easily with any other Adafruit_GFX style sketch.
David.
