I am making a IR remote controlled motor but it is not working
I am new to coding but it is not working. The problem is described in the code comments. For my circuit i just combined these too screenshots and attempted to combine the code. One screenshot is the circuit for the motor the other is for the IR receiver. I have pretty much never coded c++ before so i mainly just got Arduino to work with the physical circuits. Please help.
Also, my computer is about to die so i will respond on my other account on my phone.
//2024.04.01
My code is supposed to run a motor forward and backward, using the signals from an elegoo IR Remote and reciver module.
I am using a arduino mega. I also have a power module which is connected up to the bread board.
I am controling the motor with a L293D motor controller.
The ports things are hooked up to are as follow,
  Motor controler
    Enable- pin 5
    DIRB- pin 4
    DIRA- pin 3
  IR reciver
    G- ground (of power module)
    R- vcc (of power module)
    Y- pin 11
The code is supposed to make it so that when you push:
  volume-up it spins forward;
  pause it stops
  volume-down it spins reverse
The problem
  Whenever i press any button on the remote it imediatly starts moving the motor forward.
  I only coded C++ a few times before, so most of this code is pulled together from 2 tutorials and the internet.
  I have tried coding solutions but with my limited knowlage, it breaks the code and will not compile.
#include "IRremote.h"
#define ENABLE 5
#define DIRA 3
#define DIRB 4
int MOVEMENT = 3;
int ONE = 1;
int ZERO = 0;
int TWO = 2;
int i;
int receiver = 11; // Signal Pin of IR receiver to Arduino Digital Pin 11
/*-----( Declare objects )-----*/
IRrecv irrecv(receiver);     // create instance of 'irrecv'
//vairable uses to store the last decodedRawData
uint32_t last_decodedRawData = 0;
/*-----( Function )-----*/
void translateIR() // takes action based on IR code received
  // Check if it is a repeat IR code
  if (irrecv.decodedIRData.flags)
    //set the current decodedRawData to the last decodedRawData
    irrecv.decodedIRData.decodedRawData = last_decodedRawData;
    Serial.println("REPEAT!");
  } else
    //output the IR code on the serial monitor
    Serial.print("IR code:0x");
    Serial.println(irrecv.decodedIRData.decodedRawData, HEX);
  //map the IR code to the remote key
  switch (irrecv.decodedIRData.decodedRawData)
    case 0xBA45FF00: Serial.println("POWER"); break;
    case 0xB847FF00: Serial.println("FUNC/STOP"); break;
    case 0xB946FF00: MOVEMENT = 2; Serial.println("forward top code"); break;//this is to be volume up,   this should spin the motor forward
    case 0xBB44FF00: Serial.println("FAST BACK");    break;
    case 0xBF40FF00: MOVEMENT = 0; Serial.println("stop top code");    break;//this is to be pause, this   should stop the motor
    case 0xBC43FF00: Serial.println("FAST FORWARD");   break;
    case 0xF807FF00: Serial.println("DOWN");    break;
    case 0xEA15FF00: MOVEMENT = 2; Serial.println("reverse top code");    break;//this is to be volume down,   this should spin the motor in reverse
    case 0xF609FF00: Serial.println("UP");    break;
    case 0xE619FF00: Serial.println("EQ");    break;
    case 0xF20DFF00: Serial.println("ST/REPT");    break;
    case 0xE916FF00: Serial.println("0");    break;
    case 0xF30CFF00: Serial.println("1");    break;
    case 0xE718FF00: Serial.println("2");    break;
    case 0xA15EFF00: Serial.println("3");    break;
    case 0xF708FF00: Serial.println("4");    break;
    case 0xE31CFF00: Serial.println("5");    break;
    case 0xA55AFF00: Serial.println("6");    break;
    case 0xBD42FF00: Serial.println("7");    break;
    case 0xAD52FF00: Serial.println("8");    break;
    case 0xB54AFF00: Serial.println("9");    break;
    default:
      Serial.println(" other button   ");
  }// End Case
  //store the last decodedRawData
  last_decodedRawData = irrecv.decodedIRData.decodedRawData;
  delay(500); // Do not get immediate repeat
} //END translateIR
void setup()   /*----( SETUP: RUNS ONCE )----*/
  Serial.println("IR Receiver Button Decode");
  irrecv.enableIRIn(); // Start the receiver
  //---set pin direction
  pinMode(ENABLE,OUTPUT);
  pinMode(DIRA,OUTPUT);
  pinMode(DIRB,OUTPUT);
  digitalWrite(ENABLE,HIGH); // enable on
}/*--(end setup )---*/
void loop()   /*----( LOOP: RUNS CONSTANTLY )----*/
    if (irrecv.decode()) // have we received an IR signal?
    translateIR();
    if(MOVEMENT = ONE){
      digitalWrite(DIRA,HIGH); //forward
      digitalWrite(DIRB,LOW);
      Serial.println("FORWARD");
      irrecv.resume(); // receive the next value
    else{
      if(MOVEMENT = TWO){
        digitalWrite(DIRA,LOW);  //reverse
        digitalWrite(DIRB,HIGH);
        Serial.println("REVERSE");
      else{
      if(MOVEMENT = ZERO){
        Serial.println("OFF");
Which type of IR controller you are using?
if the below, use this IR Controller library and refer this Arduino IR car tutorial
Verify the IRremote and IRreceiver work (you can see what you sent) without a motor.
Hello this is my other account
Sorry for taking so long
I don’t know what type it is but here is a picture
It works, it won’t let me attach a video to this of the serial monitor but here is a photo
IMG_0577
You should not have two accounts.
@jake2024dowh @jake-m2024
These lines are written wrong. "=" is wrong, "==" is right
    if (MOVEMENT = ONE) {
      if (MOVEMENT = TWO) {
        if (MOVEMENT = ZERO) {
Sorry
It’s because I have one on my computer and one on my phone
Ohh ok thank you
Do you know how I can link the accounts.
Sorry I am new
Click the "flag" on any of your posts and ask the moderator to link them. Thank you.
You can use one account on multiple devices.
Thank you
Your sketch (without motors) "works"... but nearly every button wants to send the motors forward.
Why does it try to send the motors forward
Also here is a picture of the circuit in case that helps
Because the line immediately after translateIR() says to do so... when "MOVEMENT = ONE"... that is an assignment ( = ), not a comparison ( == ).
    translateIR();
      digitalWrite(DIRA, HIGH); //forward
      digitalWrite(DIRB, LOW);
