I am working on a project since some time. The project is a Robot Arm controlled by hand gestures. I am trying to control it using a glove which will use 3 flex sensors and 2 MPU6050. I am using Bluetooth to transmit the information. The robot arm is controlled by six servos. I am also using a Servo driver to control the servos. The problem I m facing is about my code. I took some inspiration from this link here: Robot Arm + Glove Code. The codes are given below:
Robot Glove:
#include <Wire.h>
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <PCA9685.h>
#include <Servo.h>
Adafruit_MPU6050 mpu1; // MPU6050 for base and wrist
Adafruit_MPU6050 mpu2; // Second MPU6050 for wrist rotation and movement
PCA9685 pwm = PCA9685();
Servo servo1; // Gripper Joint
Servo servo2; // Wrist Joint Up/Down
Servo servo3; // Wrist Rotation
Servo servo4; // Elbow Joint
Servo servo5; // Shoulder Joint
Servo servo6; // Base Joint
// Flex sensor values (hypothetical pin numbers for flex sensors)
int flexThumb = A0;
int flexIndex = A1;
int flexPinky = A2;
// Variables to hold the readings
float accelX1, accelY1, accelZ1;
float accelX2, accelY2, accelZ2;
// Initialize the PCA9685 for servo control
pwm.begin();
pwm.setPWMFreq(50); // Set the PWM frequency to 50Hz for servos
// Initialize the servos
servo1.attach(0);
servo2.attach(1);
servo3.attach(2);
servo4.attach(3);
servo5.attach(4);
servo6.attach(5);
// Initialize the MPU6050 sensors
if (!mpu1.begin()) {
Serial.println("Failed to find MPU6050 #1");
while (1);
if (!mpu2.begin()) {
Serial.println("Failed to find MPU6050 #2");
while (1);
// Initialize the flex sensors
pinMode(flexThumb, INPUT);
pinMode(flexIndex, INPUT);
pinMode(flexPinky, INPUT);
// MPU 1 Data (for base and wrist)
sensors_event_t a1, g1, temp1;
mpu1.getEvent(&a1, &g1, &temp1);
accelX1 = a1.acceleration.x;
accelY1 = a1.acceleration.y;
accelZ1 = a1.acceleration.z;
// MPU 2 Data (for wrist rotation and movement)
sensors_event_t a2, g2, temp2;
mpu2.getEvent(&a2, &g2, &temp2);
accelX2 = a2.acceleration.x;
accelY2 = a2.acceleration.y;
accelZ2 = a2.acceleration.z;
// Flex sensor readings
int thumbFlexValue = analogRead(flexThumb);
int indexFlexValue = analogRead(flexIndex);
int pinkyFlexValue = analogRead(flexPinky);
// Control Gripper Joint (Servo 1) - Index Finger Flex Sensor
if (indexFlexValue > 500) { // Adjust the threshold value as necessary
servo1.write(180); // Close gripper
servo1.write(0); // Open gripper
// Control Wrist Joint Up/Down (Servo 2) - MPU2 X/Y-Axis
if (accelY2 > 1) {
servo2.write(180); // Wrist Up
} else if (accelY2 < -1) {
servo2.write(0); // Wrist Down
// Control Wrist Rotation (Servo 3) - MPU2 Z-Axis
if (accelZ2 > 1) {
servo3.write(180); // Rotate Clockwise
} else if (accelZ2 < -1) {
servo3.write(0); // Rotate Counterclockwise
// Control Elbow Joint (Servo 4) - Thumb Finger Flex Sensor
if (thumbFlexValue > 500) {
servo4.write(180); // Bend elbow
servo4.write(0); // Extend elbow
// Control Shoulder Joint (Servo 5) - Pinkie Finger Flex Sensor
if (pinkyFlexValue > 500) {
servo5.write(180); // Move shoulder closer
servo5.write(0); // Move shoulder further
// Control Base Joint (Servo 6) - MPU1 X-Axis
if (accelX1 > 1) {
servo6.write(180); // Rotate base right
} else if (accelX1 < -1) {
servo6.write(0); // Rotate base left
delay(50); // Add a short delay to prevent too frequent updates
Robot Arm:
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
#include <SoftwareSerial.h> // Include SoftwareSerial library
// Define Bluetooth TX and RX pins
SoftwareSerial bluetooth(3, 4); // RX | TX
// Create an instance of the Adafruit PWM Servo Driver
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
const int servo_min = 150; // Minimum pulse length count (for 0 degrees)
const int servo_max = 600; // Maximum pulse length count (for 180 degrees)
// Initial parking positions of the servos
const int servo_joint_L_parking_pos = 60;
const int servo_joint_R_parking_pos = 60;
const int servo_joint_1_parking_pos = 70;
const int servo_joint_2_parking_pos = 47;
const int servo_joint_3_parking_pos = 63;
const int servo_joint_4_parking_pos = 63;
// Degree of robot servo sensitivity - Intervals
int servo_joint_L_pos_increment = 20;
int servo_joint_R_pos_increment = 20;
int servo_joint_1_pos_increment = 20;
int servo_joint_2_pos_increment = 50;
int servo_joint_3_pos_increment = 60;
int servo_joint_4_pos_increment = 40;
// Current value of the motor positions
int servo_joint_L_parking_pos_i = servo_joint_L_parking_pos;
int servo_joint_R_parking_pos_i = servo_joint_R_parking_pos;
int servo_joint_1_parking_pos_i = servo_joint_1_parking_pos;
int servo_joint_2_parking_pos_i = servo_joint_2_parking_pos;
int servo_joint_3_parking_pos_i = servo_joint_3_parking_pos;
int servo_joint_4_parking_pos_i = servo_joint_4_parking_pos;
// Minimum and maximum angle of servo motor
int servo_joint_L_min_pos = 10;
int servo_joint_L_max_pos = 180;
int servo_joint_R_min_pos = 10;
int servo_joint_R_max_pos = 180;
int servo_joint_1_min_pos = 10;
int servo_joint_1_max_pos = 400;
int servo_joint_2_min_pos = 10;
int servo_joint_2_max_pos = 380;
int servo_joint_3_min_pos = 10;
int servo_joint_3_max_pos = 380;
int servo_joint_4_min_pos = 10;
int servo_joint_4_max_pos = 120;
char state = 0; // Changes value from ASCII to char
int response_time = 5;
// Initialize Bluetooth communication
bluetooth.begin(9600); // Baud rate for Bluetooth module
Serial.begin(9600); // For debugging
// Initialize the PWM driver
pwm.begin();
pwm.setPWMFreq(60); // Analog servos run at ~60 Hz
delay(3000);
if (bluetooth.available() > 0) { // Check if data is coming from Bluetooth
state = bluetooth.read(); // Read the data from Bluetooth
Serial.print(state); // Print to Serial Monitor for debugging
// Move the servos based on received commands
if (state == 'S') {
baseRotateLeft();
delay(response_time);
if (state == 'O') {
baseRotateRight();
if (state == 'c') {
shoulderServoForward();
if (state == 'C') {
shoulderServoBackward();
if (state == 'p') {
elbowServoForward();
if (state == 'P') {
elbowServoBackward();
if (state == 'U') {
wristServo1Backward();
if (state == 'G') {
wristServo1Forward();
if (state == 'R') {
wristServoCW();
if (state == 'L') {
wristServoCCW();
if (state == 'F') {
gripperServoBackward();
if (state == 'f') {
gripperServoForward();
// Boilerplate function to move the servo motors
void gripperServoForward() {
if (servo_joint_4_parking_pos_i > servo_joint_4_min_pos) {
pwm.setPWM(5, 0, map(servo_joint_4_parking_pos_i, 0, 180, servo_min, servo_max));
Serial.println(servo_joint_4_parking_pos_i);
servo_joint_4_parking_pos_i = servo_joint_4_parking_pos_i - servo_joint_4_pos_increment;
void gripperServoBackward() {
if (servo_joint_4_parking_pos_i < servo_joint_4_max_pos) {
servo_joint_4_parking_pos_i = servo_joint_4_parking_pos_i + servo_joint_4_pos_increment;
void wristServoCW() {
if (servo_joint_3_parking_pos_i > servo_joint_3_min_pos) {
pwm.setPWM(4, 0, map(servo_joint_3_parking_pos_i, 0, 180, servo_min, servo_max));
Serial.println(servo_joint_3_parking_pos_i);
servo_joint_3_parking_pos_i = servo_joint_3_parking_pos_i - servo_joint_3_pos_increment;
void wristServoCCW() {
if (servo_joint_3_parking_pos_i < servo_joint_3_max_pos) {
servo_joint_3_parking_pos_i = servo_joint_3_parking_pos_i + servo_joint_3_pos_increment;
void wristServo1Forward() {
if (servo_joint_2_parking_pos_i < servo_joint_2_max_pos) {
pwm.setPWM(3, 0, map(servo_joint_2_parking_pos_i, 0, 180, servo_min, servo_max));
Serial.println(servo_joint_2_parking_pos_i);
servo_joint_2_parking_pos_i = servo_joint_2_parking_pos_i + servo_joint_2_pos_increment;
void wristServo1Backward() {
if (servo_joint_2_parking_pos_i > servo_joint_2_min_pos) {
servo_joint_2_parking_pos_i = servo_joint_2_parking_pos_i - servo_joint_2_pos_increment;
void elbowServoForward() {
if (servo_joint_L_parking_pos_i < servo_joint_L_max_pos) {
pwm.setPWM(0, 0, map(servo_joint_L_parking_pos_i, 0, 180, servo_min, servo_max));
pwm.setPWM(1, 0, map(servo_joint_L_max_pos - servo_joint_L_parking_pos_i, 0, 180, servo_min, servo_max));
Serial.println(servo_joint_L_parking_pos_i);
servo_joint_L_parking_pos_i = servo_joint_L_parking_pos_i + servo_joint_L_pos_increment;
void elbowServoBackward() {
if (servo_joint_L_parking_pos_i > servo_joint_L_min_pos) {
servo_joint_L_parking_pos_i = servo_joint_L_parking_pos_i - servo_joint_L_pos_increment;
void shoulderServoForward() {
if (servo_joint_1_parking_pos_i < servo_joint_1_max_pos) {
pwm.setPWM(2, 0, map(servo_joint_1_parking_pos_i, 0, 180, servo_min, servo_max));
Serial.println(servo_joint_1_parking_pos_i);
servo_joint_1_parking_pos_i = servo_joint_1_parking_pos_i + servo_joint_1_pos_increment;
void shoulderServoBackward() {
if (servo_joint_1_parking_pos_i > servo_joint_1_min_pos) {
servo_joint_1_parking_pos_i = servo_joint_1_parking_pos_i - servo_joint_1_pos_increment;
void baseRotateLeft() {
if (servo_joint_R_parking_pos_i > servo_joint_R_min_pos) {
pwm.setPWM(1, 0, map(servo_joint_R_parking_pos_i, 0, 180, servo_min, servo_max));
Serial.println(servo_joint_R_parking_pos_i);
servo_joint_R_parking_pos_i = servo_joint_R_parking_pos_i - servo_joint_R_pos_increment;
void baseRotateRight() {
if (servo_joint_R_parking_pos_i < servo_joint_R_max_pos) {
servo_joint_R_parking_pos_i = servo_joint_R_parking_pos_i + servo_joint_R_pos_increment;
Please help if you can.
