I cant connect my ESP32 with arduino ide
Sketch uses 1001605 bytes (76%) of program storage space. Maximum is 1310720 bytes.
Global variables use 45508 bytes (13%) of dynamic memory, leaving 282172 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.6
Serial port COM3
A fatal error occurred: Could not open COM3, the port doesn't exist
Failed uploading: uploading error: exit status 2
I've moved your topic from IDE 1.x to an section of the forum that is more suitable for upload problems.
I have no experience with the ESP32 (and probably can't help further) but answers to below questions can help others to help you.
  1. Which exact ESP32 board do you use?
  2. Is COM3 indeed your ESP32? Does it disappear from the list of ports when you disconnect the board?
  3. Anything in Windows device manager indicating a problem?
  4. Which version of the IDE are you using? You did post in IDE 1.x but that is not always a guarantee that one posted in then correct section (no offence intended).
Did you select it or did the IDE. Check the tools and be sure the correct board is selected.
