I cant fix my code for my joystick
i made this code and it kept giviing me this : /usr/local/bin/arduino-cli compile --fqbn arduino:avr:uno --build-cache-path /tmp --output-dir /tmp/1358584767/build --build-path /tmp/arduino-build-2B663BB633FACCC1D1731B2FDFC04063 /tmp/1358584767/new_sketch_1726864081254
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino: In function 'void loop()':
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:16:14: error: a function-definition is not allowed here before '{' token
void setup() {}
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:21:6: error: redefinition of 'void loop()'
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:9:6: note: 'void loop()' previously defined here
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:23:5: error: 'modo' was not declared in this scope
modo = Serial.read(); //Lê o caractere e guarda na variável sentido
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:23:5: note: suggested alternative: 'modf'
modf
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:28:11: error: 'modo' was not declared in this scope
switch (modo) {
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:28:11: note: suggested alternative: 'modf'
switch (modo) {
modf
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino: In function 'void leitura()':
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:42:31: error: 'x' was not declared in this scope
Serial.println(analogRead(x));
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:44:31: error: 'y' was not declared in this scope
Serial.println(analogRead(y));
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:46:32: error: 'botao' was not declared in this scope
Serial.println(digitalRead(botao));
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino: In function 'void movimento()':
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:54:21: error: 'x' was not declared in this scope
if ((analogRead(x)) == 0) {
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:57:21: error: 'x' was not declared in this scope
if ((analogRead(x)) == 1023) {
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:60:21: error: 'y' was not declared in this scope
if ((analogRead(y)) == 0) {
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:63:21: error: 'y' was not declared in this scope
if ((analogRead(y)) == 1023) {
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:66:22: error: 'botao' was not declared in this scope
if ((digitalRead(botao)) == 0) {
/tmp/1358584767/new_sketch_1726864081254/new_sketch_1726864081254.ino:69:22: error: expected primary-expression before 'int'
if ((digitalRead(int:botao)) == 1) {
Error during build: exit status 1
please help
also it kept giving me this error if i ACTUALLY USED 'int'
You have to show us the source code enclosed in code tags.
Post the code.
That kind of error could be as simple as a forgotten semicolon somewhere near the line(s) it complains about.
Ask me how I know.
a7
I believe you have copy/pasted a program INSIDE the minimal.ino sketch:
  // something
    // other
You have something that looks like this:
  // part of minimal.ino
    // redefinition - copy/pasted program
Which gives you this type of error..
sketch.ino: In function 'void loop()':
sketch.ino:6:16: error: a function-definition is not allowed here before '{' token
sketch.ino:9:15: error: a function-definition is not allowed here before '{' token
The program looks like an etch-a-sketch with a joystick and MAX7219 dot-matrix, using Serial.read(); to draw/erase (modo).
int joyX = A0; // pino analógico do eixo X
int joyY = A1; // pino analógico do eixo Y
int joyButton = 2; // pino digital do botão de pressão
int Serial.begin(9600); // inicia comunicação serial
pinMode[(joyX, INPUT); // entrada leitura eixo X joystick
pinMode[(joyY, INPUT); // entrada leitura eixo y joystick
pinMode[(joyButton, INPUT_PULLUP) // entrada resistor interno pull up pusch button
int x = analogRead(joyX); // faz a leitura do eixo x (0 a 1023) - analógico
int y = analogRead(joyY); // faz a leitura do eixo y (0 a 1023) - analógico
int button = digitalRead(joyButton); // faz a leitura do eixo z (0 ou 1) - digital
Serial.print("X: ");
Serial.print(x);
Serial.print(", Y: ");
Serial.print(y);
Serial.print(", Button: ");
Serial.println(button);
delay(100);
this is my code
i use an arduino uno.
strange... whenever i use 'int:' it gets blue
guys im anoob
Remove all occurrences of "["
Add an opening brace "{" and close brace "}" around the code in the setup() function...
Remove int before Serial.begin();
Add semicolon ";" at the end of pinMode(joyButton, INPUT_PULLUP);
{ // OPEN BRACE
  // int Serial.begin(9600); // inicia comunicação serial // REMOVE INT
  pinMode(joyX, INPUT); // entrada leitura eixo X joystick
  pinMode(joyY, INPUT); // entrada leitura eixo y joystick
  // pinMode(joyButton, INPUT_PULLUP) // entrada resistor interno pull up pusch button
  pinMode(joyButton, INPUT_PULLUP); // ADD ";" SEMICOLON
} // CLOSE BRACE
ok lemme try it now
/usr/local/bin/arduino-cli compile --fqbn arduino:avr:uno --build-cache-path /tmp --output-dir /tmp/3903922206/build --build-path /tmp/arduino-build-2B663BB633FACCC1D1731B2FDFC04063 /tmp/3903922206/new_sketch_1726864081254
/tmp/3903922206/new_sketch_1726864081254/new_sketch_1726864081254.ino:15:4: error: expected initializer before 'Serial'
/tmp/3903922206/new_sketch_1726864081254/new_sketch_1726864081254.ino:16:11: error: expected constructor, destructor, or type conversion before '(' token
/tmp/3903922206/new_sketch_1726864081254/new_sketch_1726864081254.ino:17:11: error: expected constructor, destructor, or type conversion before '(' token
/tmp/3903922206/new_sketch_1726864081254/new_sketch_1726864081254.ino:18:11: error: expected constructor, destructor, or type conversion before '(' token
pinMode(joyButton, INPUT_PULLUP); // entrada resistor interno pull up pusch button
You did not make all the changes.
Remember to post your new code when you change the old code. When posting code, click the < CODE > button and paste your code where you see ```type or paste code here```
okay
void {setup()}
pinMode{(joyX, INPUT)}; // entrada leitura eixo X joystick
pinMode{(joyY, INPUT)}; // entrada leitura eixo y joystick
void {loop()}
int x = analogRead{(joyX)}; // faz a leitura do eixo x (0 a 1023) - analógico
int y = analogRead{(joyY)}; // faz a leitura do eixo y (0 a 1023) - analógico
Serial.print(x);
Serial.print(y);
delay{(100)};
just modified it
void {setup()}
void {loop()}
Serial.print(x);
Serial.print(y);
delay(100);
once again modified :
void {setup()}
pinMode(joyButton, INPUT_PULLUP);// entrada resistor interno pull up pusch button//added the semicolon
void {loop()}
Serial.print(x);
Serial.print(y);
delay(100);
{void setup()}
{void loop()}
Serial.print(x);
Serial.print(y);
delay(100);
again modified
