I'm using a UNO. A push button is conected between pin 2 and ground. Then I have this:
attachInterrupt(0,blink,LOW);
I understand that in this board I don't have to tell which pin is triggering the interrupt, as any between 2 and 3 will do (0 is the interrupt number).
and this is blink (besides the blinking, the variable autom should toogle between false and true);
Even detaching the interrupt at the beginning doesn't prevent the variable autom to change values three times, in most ocurrences, thus keeping the initial value;sometimes it works.
Why are you attaching and detaching interrupts inside an ISR? Also, delay() won't work inside in in ISR. It's also a terrible idea to allow an ISR to run for extended time periods.
Interrupt 0 only applies to pin 2, not pin 3 as well. Forever avoid any source of information that told you that.
rva1945:
I added Serial.print in order to see what whas happening as it was already failing to properly work.
And thereby almost guaranteeing that it would fail.
When you send a string to be printed, it is added character-by-character to a memory buffer of finite length.
If there is no space in the buffer, the print method must wait until there is.
When the UART signals that its transmit buffer is empty, and interrupt is generated, and the interrupt service routine takes a character from the buffer and writes it to the transmit register, and adjusts the buffer pointer to indicate that there is a space.
If your process is in your interrupt service routine, interrupts are disabled, so the UART cannot signal an empty register, so you'll keep adding characters tot the transmit buffer until it is full.
So, the print method will spin, waiting for space in the buffer, which will never happen, because nothing can empty the buffer.
Deadlock.
