i want to mesure a motor's vibration
so i put adxl on the top and side of the motor, and turned on the motor and tried to watch serial monitor
but when motor begins to rotate, it stopped to send data.
ho can i fix that?
here's the code what i used
#include <Wire.h> //horizental
#define I2C_Address 0x53
//ADXL345 register address
#define POWER_CTL 0x2D
#define DATA_FORMAT 0x31
#define X_axis 0x32
#define Y_axis 0x34
#define Z_axis 0x36
#define Range_2g 0
#define Range_4g 1
#define Range_8g 2
#define Range_16g 3
Wire.begin(); // 센서 작동 시작
Serial.begin(9600); // 통신속도 9600으로 설정
Init_ADXL345(Range_4g);
Serial.println("CLEARDATA");
Serial.println("X,Y,Z");
//3축 출력
Serial.print("DATA,");
Serial.print(Read_Axis(X_axis));
Serial.print(", ");
Serial.print(Read_Axis(Y_axis));
Serial.print(", ");
Serial.print(Read_Axis(Z_axis));
delay(20);
//I2C인터페이스를 통해 축을 읽음
int Read_Axis(byte a) {
int data;
Wire.beginTransmission(I2C_Address);
Wire.write(a);
Wire.endTransmission();
Wire.requestFrom(I2C_Address, 2);
if (Wire.available()) {
data = (int)Wire.read();
data = data | (Wire.read() << 8);
else {
data = 0;
return data;
//ADXL345 초기화
void Init_ADXL345(byte r) {
//감도설정
Wire.write(DATA_FORMAT);
Wire.write(r);
//측정모드로 전환
Wire.write(POWER_CTL);
Wire.write(0x08);
