Hello there i recently bought an esp32 cam from Aliexpress. I dont have Fdti Adapter or whatever is called to Programm the Esp32 cam . However i have an Arduino Uno to programm the Esp32 cam. So i went on youtube like all of us do to see how to do it(like wiring && driver and all that stuff). However i am getting an Fatal Error. Any Solution
Sketch uses 263222 bytes (8%) of program storage space. Maximum is 3145728 bytes.
Global variables use 13380 bytes (4%) of dynamic memory, leaving 314300 bytes for local variables. Maximum is 327680 bytes.
esptool.py v3.0-dev
Serial port COM7
Connecting........_____....._____....._____....._____....._____....._____.....____An error occurred while uploading the sketch
_
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
Invalid library found in C:\Users\Aesha\Documents\Arduino\libraries\Wifi-Setup-Esp8266: no headers files (.h) found in C:\Users\Aesha\Documents\Arduino\libraries\Wifi-Setup-Esp8266
Ok my bad! So i bought Esp32-cam from Aliexpress and i tried to programm it with my Arduino Uno.
The Connection were ´:
Esp 5V to Uno 5V
Esp gnd to Uno gnd
Esp IO0 to Esp gnd
Esp Tx to Uno Tx
Esp Rx to Uno Rx
Uno Reset to Uno gnd
After the wiring/connecting Esp32-cam with Uno i pasted this link( https://dl.espressif.com/dl/package_esp32_index.json) in Prefrences and download the Esp32 board manager. After installing it i choose Esp32 wroover Module.
The setting for the Upload were:
Upload speed: 115200
Flash frequenzy. 40Mhz
Flashmode: QIO
Partion scheme: Huge APP 3mb(...)
Code debug level: none
Programmer: none Selected
