i tried many times changing the cable, the computer usb port but didnt work. the device is visible in the computer.
the error:
In file included from /tmp/1069579387/Plant_Watering_Kit_aug26a/Plant_Watering_Kit_aug26a.ino:36:0: /tmp/1069579387/Plant_Watering_Kit_aug26a/thingProperties.h: In function 'void initProperties()': /tmp/1069579387/Plant_Watering_Kit_aug26a/thingProperties.h:18:3: error: 'ArduinoCloud' was not declared in this scope ArduinoCloud.addProperty(moisture, READ, ON_CHANGE, NULL); ^~~~~~~~~~~~ /tmp/1069579387/Plant_Watering_Kit_aug26a/thingProperties.h:18:3: note: suggested alternative: 'Arduino_h' ArduinoCloud.addProperty(moisture, READ, ON_CHANGE, NULL); ^~~~~~~~~~~~ Arduino_h /tmp/1069579387/Plant_Watering_Kit_aug26a/Plant_Watering_Kit_aug26a.ino: In function 'void setup()': /tmp/1069579387/Plant_Watering_Kit_aug26a/Plant_Watering_Kit_aug26a.ino:56:3: error: 'ArduinoCloud' was not declared in this scope ArduinoCloud.begin(ArduinoIoTPreferredConnection); ^~~~~~~~~~~~ /tmp/1069579387/Plant_Watering_Kit_aug26a/Plant_Watering_Kit_aug26a.ino:56:3: note: suggested alternative: 'Arduino_h' ArduinoCloud.begin(ArduinoIoTPreferredConnection); ^~~~~~~~~~~~ Arduino_h /tmp/1069579387/Plant_Watering_Kit_aug26a/Plant_Watering_Kit_aug26a.ino: In function 'void loop()': /tmp/1069579387/Plant_Watering_Kit_aug26a/Plant_Watering_Kit_aug26a.ino:71:3: error: 'ArduinoCloud' was not declared in this scope ArduinoCloud.update(); ^~~~~~~~~~~~ /tmp/1069579387/Plant_Watering_Kit_aug26a/Plant_Watering_Kit_aug26a.ino:71:3: note: suggested alternative: 'Arduino_h' ArduinoCloud.update(); ^~~~~~~~~~~~ Arduino_h Multiple libraries were found for "ArduinoIoTCloud.h" Used: /mnt/create-efs/webide/89/4c/894cfbf221f02659023a3129a6c28207:marwan09/libraries_v2/ArduinoIoTCloud Not used: /home/builder/opt/libraries/arduinoiotcloud_1_12_0 Multiple libraries were found for "WiFiNINA.h" Used: /home/builder/opt/libraries/wifinina_1_8_14 Not used: /home/builder/opt/libraries/vega_wifinina_1_0_1 Multiple libraries were found for "SPI.h" Used: /home/builder/.arduino15/packages/arduino/hardware/mbed_nano/4.0.2/libraries/SPI Not used: /home/builder/opt/libraries/eventethernet_1_0_0 Error during build: exit status 1
