I couldn't figure out why i can't use SHT21 within my sketch
I wrote a very big sketch, i connected a lot of stuff to my UNO R4 WiFi because i want to learn everything :slight_smile:
Now i connected a working, tested SHT21 board (i tested with the example provided, i also copied it to my sketch just to be sure while not changing any wiring but still doesn't succeed this way).
I couldn't make it print anything else to serial than Temp: -46.85 Humidity: -6.00 while the example gives me the correct Temp: 29.17 Humidity: 59.80 values.
#include "SPI.h"
//#include "IRremote.hpp"
#include "SHT21.h"
#include "Arduino_LED_Matrix.h"
#include "animation.h"
ArduinoLEDMatrix matrix;
SHT21 sht;
const int buttonPin = 7;
const int potmeterPin = A1;
const int lightSensorPin = A0;
const int rgbRPin = 3; //PWM
const int rgbGPin = 5; //PWM
const int rgbBPin = 6; //PWM
const int irSensorPin = 4;
const int greenLedPin = 2;
const int buzzerPin = 8;
const int redLedPin = 9;
const int slaveSelect = 12;
const int numberOfDigits = 4;
const int greenLedInterval = 500;
const int buzzerInterval = 100;
const int buttonInterval = 200;
const int LDRInterval = 100;
const int potInterval = 100;
const int pwmInterval = 5;
const int rgbFunInterval = 10;
const int displayRefreshInterval = 100;
const int irInterval = 5;
const int tempAndHumInterval = 100;
unsigned long currentMillis = 0;
unsigned long previousGreenLedMillis = 0;
unsigned long previousBuzzerMillis = 0;
unsigned long previousButtonMillis = 0;
unsigned long previousLDRMillis = 0;
unsigned long previousPotMillis = 0;
unsigned long previousPWMMillis = 0;
unsigned long previousRGBFun = 0;
unsigned long previousDisplayRefreshMillis = 0;
unsigned long previousIrMillis = 0;
unsigned long previousTempAndHumMillis = 0;
byte greenLedState = LOW;
byte buttonState = HIGH;
byte buzz = false;
int LDRValue;
int mappedLDRValue;
int potValue;
int mappedPotValue;
int pwmDuty;
int rgbRduty = 0;
int rgbGduty = 0;
int rgbBduty = 0;
byte rgbRUp = true;
byte rgbGUp = true;
byte rgbBUp = true;
float temp;
float humidity;
long randNumber;
//IRrecv irrecv(irSensorPin);
//decode_results results;
  Wire.begin();
  SPI.begin();
  //irrecv.enableIRIn();
  pinMode(buttonPin, INPUT_PULLUP);
  pinMode(potmeterPin, INPUT);
  pinMode(lightSensorPin, INPUT);
  pinMode(rgbRPin, OUTPUT);
  pinMode(rgbGPin, OUTPUT);
  pinMode(rgbBPin, OUTPUT);
  pinMode(irSensorPin, INPUT);
  pinMode(greenLedPin, OUTPUT);
  pinMode(buzzerPin, OUTPUT);
  pinMode(redLedPin, OUTPUT);
  pinMode(slaveSelect, OUTPUT);
  digitalWrite(slaveSelect, LOW);
  sendCommand (12, 1); //normal mode (default is shutdown mode)
  sendCommand (15, 0); //display test off
  sendCommand (10, 0); //set light intensity (range is 0-15)
  sendCommand (11, numberOfDigits); //7219 digit scan limit command
  sendCommand (9, 255); //decode command, use standard 7-segment digits
  digitalWrite(slaveSelect, HIGH);
  randomSeed(analogRead(A5));
  matrix.loadSequence(dinosaur);
  matrix.begin();
  matrix.play(true);
  currentMillis = millis();
  //greenLedBlinking();
  buttonRead();
  LDR();
  potRead();
  //irReceiving();
  tempAndHum();
  switchLED();
  pwm(redLedPin);
  //rgbFun();
  soundBuzzer();
  displayRefresh();
void greenLedBlinking() {
  if (greenLedState == LOW) {
    if(currentMillis - previousGreenLedMillis >= greenLedInterval) {
      greenLedState = HIGH;
      previousGreenLedMillis += greenLedInterval;
void buttonRead() {
  if (currentMillis - previousButtonMillis >= buttonInterval) {
    if(digitalRead(buttonPin) == LOW) {
      buttonState = !buttonState;
      greenLedState = !greenLedState;
      buzz = true;
    previousButtonMillis += buttonInterval;
void LDR() {
  if(currentMillis - previousLDRMillis >= LDRInterval) {
    LDRValue = analogRead(lightSensorPin);
    mappedLDRValue = map(LDRValue, 1023, 0, 0, 15);
    previousLDRMillis += LDRInterval;
void potRead() {
  if(currentMillis - previousPotMillis >= potInterval) {
    potValue = analogRead(potmeterPin);
    pwmDuty = potValue / 4;
    mappedPotValue = map(potValue, 0, 1023, 0, 100);
    previousPotMillis += potInterval;
void switchLED() {
  digitalWrite(greenLedPin, greenLedState);
void pwm(int pwmPin) {
  if(currentMillis - previousPWMMillis >= pwmInterval) {
    analogWrite(pwmPin, pwmDuty);
    previousPWMMillis += pwmInterval;
void rgbFun() {
  if(currentMillis - previousRGBFun >= rgbFunInterval) {
    randNumber = random(1, 4);
    switch(randNumber) {
      case 1:
        if(rgbRUp) {
          rgbRduty++;
          analogWrite(rgbRPin, rgbRduty);
          if(rgbRduty >= 255) rgbRUp = false;
          rgbRduty--;
          if(rgbRduty <= 0) rgbRUp = true;
      case 2:
        if(rgbGUp) {
          rgbGduty++;
          analogWrite(rgbGPin, rgbGduty);
          if(rgbGduty >= 255) rgbGUp = false;
          rgbGduty--;
          if(rgbGduty <= 0) rgbGUp = true;
      case 3:
        if(rgbBUp) {
          rgbBduty++;
          analogWrite(rgbBPin, rgbBduty);
          if(rgbBduty >= 255) rgbBUp = false;
          rgbBduty--;
          if(rgbBduty <= 0) rgbBUp = true;
    previousRGBFun += rgbFunInterval;
void soundBuzzer() {
  if(currentMillis - previousBuzzerMillis >= buzzerInterval) {
    if(buzz == true) {
      tone(buzzerPin, 1000);
      buzz = false;
      noTone(buzzerPin);
    previousBuzzerMillis += buzzerInterval;
void displayRefresh() {
  if(currentMillis - previousDisplayRefreshMillis >= displayRefreshInterval) {
    //sendCommand (10, mappedLDRValue); //set light intensity (range is 0-15)
    displayNumber(mappedPotValue);
    previousDisplayRefreshMillis += displayRefreshInterval;
void displayNumber (int number) {
  for (int i=0; i < numberOfDigits; i++) {
    byte character= number % 10; //get the value of the rightmost digit
    if (number == 0 && i > 0) {
      character = 0xf;
    sendCommand(numberOfDigits-i, character);
    number= number/10;
void sendCommand(int command, int value) {
  SPI.transfer(command);
  SPI.transfer(value);
void irReceiving() {
  if(currentMillis - previousIrMillis >= irInterval) {
    if (irrecv.decode(&results)) {
      Serial.println(results.value, DEC);
      dump(&results);
      irrecv.resume(); // Receive the next value
    previousIrMillis += irInterval;
//void dump(decode_results *results) {
  // Dumps out the decode_results structure.
  // Call this after IRrecv::decode()
  int count = results->rawlen;
  if (results->decode_type == UNKNOWN) {
    Serial.print("Unknown encoding: ");
  else if (results->decode_type == NEC) {
    Serial.print("Decoded NEC: ");
  else if (results->decode_type == SONY) {
    Serial.print("Decoded SONY: ");
  else if (results->decode_type == RC5) {
    Serial.print("Decoded RC5: ");
  else if (results->decode_type == RC6) {
    Serial.print("Decoded RC6: ");
  else if (results->decode_type == PANASONIC) {
    Serial.print("Decoded PANASONIC - Address: ");
    Serial.print(results->address, HEX);
    Serial.print(" Value: ");
  else if (results->decode_type == LG) {
    Serial.print("Decoded LG: ");
  else if (results->decode_type == JVC) {
    Serial.print("Decoded JVC: ");
  else if (results->decode_type == AIWA_RC_T501) {
    Serial.print("Decoded AIWA RC T501: ");
  else if (results->decode_type == WHYNTER) {
    Serial.print("Decoded Whynter: ");
  Serial.print(results->value, HEX);
  Serial.print(" (");
  Serial.print(results->bits, DEC);
  Serial.println(" bits)");
  Serial.print("Raw (");
  Serial.print(count, DEC);
  Serial.print("): ");
  for (int i = 1; i < count; i++) {
    if (i & 1) {
      Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
    else {
      Serial.write('-');
      Serial.print((unsigned long) results->rawbuf[i]*USECPERTICK, DEC);
    Serial.print(" ");
void tempAndHum() {
  if(currentMillis - previousTempAndHumMillis >= tempAndHumInterval) {
    temp = sht.getTemperature();
    humidity = sht.getHumidity();
    Serial.print("Temp: ");
    Serial.print(temp);
    Serial.print("\t Humidity: ");
    Serial.println(humidity);
    previousTempAndHumMillis += tempAndHumInterval;
The function is at the very bottom, i have no electrical shorts and the example code below works just fine.
//    E - R A D I O N I C A . C O M,  H.Kolomana 6/A, Djakovo 31400, Croatia
// Project   :  SHT21 Arduino Library
// File      :  SHT21 Demo Arduino Example
// Author    :  e-radionica.com 2017
// Licence   :  Open-source !
// Use with any SHT21 breakout. Check ours:
// https://e-radionica.com/en/sht21-humidity-and-temperature-sensor.html
// Shows temperature and humidity from SHT21 sensor in Serial monitor.
// If any questions,
// just contact techsupport@e-radionica.com
#include <SHT21.h>  // include SHT21 library
SHT21 sht;
float temp; 	// variable to store temperature
float humidity; // variable to store hemidity
  Wire.begin();		// begin Wire(I2C)
  Serial.begin(9600); // begin Serial
  temp = sht.getTemperature();  // get temp from SHT
  humidity = sht.getHumidity(); // get temp from SHT
  Serial.print("Temp: ");			// print readings
  Serial.print(temp);
  delay(85);	// min delay for 14bit temp reading is 85ms
Now i also found out that everything went super laggy while i got the wrong values on the Serial. I mean the connected potmeter, button and 7 segment display all went to like 1fps, i need to hold down a lot the button for it to register, the buzzer buzzes longer than it should etc..
Almost if i used some delay() every time i access the sensor.
Can i get a little help? :slight_smile:
I solved it, the problem was on line 102.
In line 102 i used randomSeed(analogRead(A5)); to get a real random number for my rgb led color shifting function by reading an unconnected analog pin as a seed. On every Arduino UNO the SDA and SCL pins shared with the A5 and A4 pins, thus i needed to change it to A3 (unused analog pin), and now it works fine!
Good to know that it is working. If you ever consider to make an SHT21-based module by yourself, you can design and print PCB like this:
