CAN YOU HELP ME ?
(On "ARDUINO UNO")
real question:
J'ai crée un code et il y a une erreur pouvez vous m'aider ?
The error message says:
Compilation error: a function-definition is not allowed here before '{' token
Here is the code:
#define LED 13
#define LED1 12
#define LED2 11
#define BUTTON 10
const int ledPin = 9;
int buttonState = 0;
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
pinMode(ledPin, OUTPUT);
pinMode(10, INPUT);
digitalWrite (LED, HIGH);
Serial.println("LED R ALUMEE");
delay (5000);
digitalWrite (LED, LOW);
Serial.println("LED R ETEINTE");
digitalWrite (LED1, HIGH);
Serial.println("LED V ALUMEE");
delay (5000);
digitalWrite (LED1, LOW);
Serial.println("LED V ETEINTE");
digitalWrite (LED2, HIGH);
Serial.println("LED G ALUMEE");
delay (2000);
digitalWrite (LED2, LOW);
Serial.println("LED G ETEINTE");
if(buttonState == HIGH) {
void loop (){ //it's here
digitalWrite(ledPin, HIGH);
Thanks in advance
LarryD
2
This is wrong.
Why do you have a (second) definition of loop() inside the if in loop()?
Hmm, @LarryD is faster
horace
5
you appear to be defining function loop() twice in lines 22 and 39
try removing line 39
Good morning
Duplicate post with this one:
Can a moderator close this topic, knowing that the solution was provided in the French category topic?
@dariusistoc1 Read Les bonnes pratiques du forum francophone and apply them. In particular, do not create duplicate topics.
Thanks in advance
Friendships
Remi
