I dont know how to respond to the error message "AO not declared in this scope"?
I'm just trying the 3rd project in the book - I get the message "AO not declared in this scope". When I look in the troubleshooting section, it tells me to "provide your own, or place the definition of the function above any calls to it."
Isnt this what I'm doing? How do I do that if not like below?
const int sensorPin = AO;
const float baselineTemp = 21.0;
void setup(){
Serial.begin(9600); // open a serial port
for(int pinNumber = 2; pinNumber<5; pinNumber++){
pinMode(pinNumber,OUTPUT);
digitalWrite(pinNumber, LOW);
void loop(){
int sensorVal = analogRead(sensorPin);
Serial.print("Sensor Value: ");
Serial.print(sensorVal);
//convert the ADC reading to voltage
float voltage = (sensorVal/1024,0) * 5.0;
Serial.print(", Volts: ");
Serial.print(voltage);
Serial.print(", degrees C: ");
// convert the voltage to temp. in degrees
float temperature = (voltage - .5) * 100;
Serial.println(temperature);
if(temperature < baselineTemp){
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
}else if(temperature >= baselineTemp+2 &&
temperature < baselineTemp+4){
digitalWrite(2, HIGH);
}else if(temperature >= baselineTemp+4 &&
temperature < baselineTemp+6){
digitalWrite(3, HIGH);
}else if(temperature >= baselineTemp+6){
digitalWrite(4, HIGH);
delay(1);
Try replacing AO with A0. That is a capital o with a zero.
