I have a question about how to control time with the millis() function.
Hello, everyone!
I'm writing code using the millis() function. I think the code is twisted because I'm not good at coding yet and I don't understand millis(). The code below provides an inclination through the 9-axis sensor and outputs different strings and LEDs depending on the left and right slopes.
What I want to do is, for example, tilt to the left, the functions below are implemented.
  1. Left LED illuminated for 1 second (if tilted to the left continuously, it remains on until switching to another direction).)
  2. Switching to the right before 1 second (not yet before LED goes off) turns the left LED off immediately and performs the right LED action.
+3. LED Immediate Switching only applies when tilting left or right. For example, if you tilt to the left and then place it in a flat state, the left LED turns on and then turns off after a second.
It's kind of like this, but I couldn't express it properly with code...
If I upload this code, you will only repeat the on/off toggle when it is within the specified value range.
//Based on the x-axis slope.
if(val_x < -30 && State == 0) //  right on
      State = 1;
      unsigned long previousMillis = millis();
      Serial.println("갸LED ON");
      digitalWrite(right_led, HIGH);
      digitalWrite(left_led, LOW);
    else if(val_x > 30 && State == 0) // left on
      State = 1;
      Serial.println("왼쪽 LED ON");
      digitalWrite(left_led, HIGH);
      digitalWrite(right_led, LOW);
      State = 0;
    if( millis() >= previousMillis + 1000 && State == 0)//OFF
      Serial.println("LED OFF");
I would really appreciate it if you could tell me about my problem!
Thank you.
A millis() timing check should never be embedded in a conditional statement. If the conditional statement remains false for longer than the timing interval, the timing update will be missed.
Some pseudo code...
Now = millis()
If left sensor detected
  If Left == LOW
    LeftStart = Now
  Left = HIGH
Else If Now - LeftStart >= 1000
  Left = LOW
If right sensor detected
  If Right == LOW
    RightStart = Now
  Right = HIGH
Else If Now - RightStart >= 1000
  Right = LOW
digitaWrite(leftLed, Left)
digitalWrite(rightLed, Right)
Please pay attention to the following:
  • the previousMillis variable MUST be a global variable.
  • checking time should NOT be inside any conditional block. make sure that is always check in the loop regardless any condition.
You can refer to how to use millis() function
Thank you all for your help! I'll refer to it and revise it.
You are going to be disappointed. Nobody has the power to control time :slight_smile:
The demo Several Things at a Time illustrates the use of millis() to manage timing without blocking. It may help with understanding the technique.
Have a look at Using millis() for timing. A beginners guide if you need more explanation.
...R
IoT_hobbyist:
...or it could be a static variable.
This topic has been merged into I'm trying to control LED blinking within the range of the sensor values..
