int redPin=11; //set red LED pin to 11
int greenPin=10; //set green LED pin to 10
int bluePin=6; //set blue LED pin to 6
int brightness=255; //Set brightness to 255
String colorChoice; //Will hold users input of color choice
Serial.begin(9600); //Turn on Serial port
pinMode(redPin, OUTPUT); //Set redPin to be an output
pinMode(greenPin, OUTPUT); //Set greenPin to be an output
pinMode(bluePin, OUTPUT); //set bluePin to be an output
Serial.println("What color would you like the LED? (red, green, or blue)"); //Prompt user for color
while (Serial.available()==0) { } //Wait for input
colorChoice = Serial.readString();
if (colorChoice=="red") {
analogWrite(redPin, brightness); //turn on red pin
analogWrite(greenPin, 0); //turn off green pin
analogWrite(bluePin, 0); //write off blue pin
if (colorChoice=="blue") {
analogWrite(redPin, 0); //turn off red pin
analogWrite(bluePin, brightness); //write on blue pin
if (colorChoice=="green") {
analogWrite(greenPin, brightness); //turn on green pin
if (colorChoice!="red" && colorChoice!="green" && colorChoice != "blue") {
Serial.println("That is not a valid color choice, please try again");
Serial.println("");
I open serial monitor and type red for example. I receive message That is not a valid color choice, please try again. Can you spot any mistakes on this?
P.s The circuit itself is working. But code not
