I have probleme in my switch/case when i add to statement
switch(receivedValue){
          case 0:
          digitalWrite(led1, LOW);
          case 1:
          digitalWrite(led1, HIGH);
          case 2:
          digitalWrite(led2, HIGH);
          case 3:
          digitalWrite(led2, LOW);
          case 4:
          digitalWrite(led3, HIGH);
          case 5:
          digitalWrite(led3, LOW);
          case 6:
          digitalWrite(led4, HIGH);
          case 7:
          digitalWrite(led4, LOW);
when my code is like up there it works normally but when i add a second statement like the code below it stops working
          case 0:
          case 1:
          digitalWrite(buzz, HIGH);
          case 2:
          case 3:
          case 4:
          case 5:
          case 6:
          case 7:
the complete code is
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/esp32-web-bluetooth/
  Permission is hereby granted, free of charge, to any person obtaining a copy
  of this software and associated documentation files.
  The above copyright notice and this permission notice shall be included in all
  copies or substantial portions of the Software.
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
BLEServer* pServer = NULL;
BLECharacteristic* pSensorCharacteristic = NULL;
BLECharacteristic* pLedCharacteristic = NULL;
bool deviceConnected = false;
bool oldDeviceConnected = false;
uint32_t value = 0;
int led1 = 13;
int led2 = 12;
int led3 = 14;
int led4 = 27;
int btn = 25;
int buzz = 26;
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID        "19b10000-e8f2-537e-4f6c-d104768a1214"
#define SENSOR_CHARACTERISTIC_UUID "19b10001-e8f2-537e-4f6c-d104768a1214"
#define LED_CHARACTERISTIC_UUID "19b10002-e8f2-537e-4f6c-d104768a1214"
class MyServerCallbacks: public BLEServerCallbacks {
    void onConnect(BLEServer* pServer) {
      deviceConnected = true;
    void onDisconnect(BLEServer* pServer) {
class MyCharacteristicCallbacks : public BLECharacteristicCallbacks {
    void onWrite(BLECharacteristic* pLedCharacteristic) {
        std::string value = pLedCharacteristic->getValue();
        if (value.length() > 0) {
            int receivedValue = static_cast<int>(value[0]);
            Serial.println(receivedValue);
          case 0:
          case 1:
          case 2:
          case 3:
          case 4:
          case 5:
          case 6:
          case 7:
    if(digitalRead(btn)== HIGH){
      digitalWrite(buzz, LOW);
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  pinMode(buzz, OUTPUT);
  pinMode(btn, INPUT);
  // Create the BLE Device
  BLEDevice::init("ESP32");
  // Create the BLE Server
  pServer = BLEDevice::createServer();
  pServer->setCallbacks(new MyServerCallbacks());
  // Create the BLE Service
  BLEService *pService = pServer->createService(SERVICE_UUID);
  // Create a BLE Characteristic
  pSensorCharacteristic = pService->createCharacteristic(
                      SENSOR_CHARACTERISTIC_UUID,
                      BLECharacteristic::PROPERTY_READ   |
                      BLECharacteristic::PROPERTY_WRITE  |
                      BLECharacteristic::PROPERTY_NOTIFY |
                      BLECharacteristic::PROPERTY_INDICATE
  // Create the ON button Characteristic
  pLedCharacteristic = pService->createCharacteristic(
                      LED_CHARACTERISTIC_UUID,
  // Register the callback for the ON button characteristic
  pLedCharacteristic->setCallbacks(new MyCharacteristicCallbacks());
  // https://www.bluetooth.com/specifications/gatt/viewer?attributeXmlFile=org.bluetooth.descriptor.gatt.client_characteristic_configuration.xml
  // Create a BLE Descriptor
  pSensorCharacteristic->addDescriptor(new BLE2902());
  pLedCharacteristic->addDescriptor(new BLE2902());
  // Start the service
  pService->start();
  // Start advertising
  BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
  pAdvertising->addServiceUUID(SERVICE_UUID);
  pAdvertising->setScanResponse(false);
  pAdvertising->setMinPreferred(0x0);  // set value to 0x00 to not advertise this parameter
  BLEDevice::startAdvertising();
  Serial.println("Waiting a client connection to notify...");
    // notify changed value
    if (deviceConnected) {
        pSensorCharacteristic->setValue(String(value).c_str());
        pSensorCharacteristic->notify();
        value++;
        Serial.print("New value notified: ");
        Serial.println(value);
        delay(3000); // bluetooth stack will go into congestion, if too many packets are sent, in 6 hours test i was able to go as low as 3ms
    // disconnecting
    if (!deviceConnected && oldDeviceConnected) {
        Serial.println("Device disconnected.");
        delay(500); // give the bluetooth stack the chance to get things ready
        pServer->startAdvertising(); // restart advertising
        Serial.println("Start advertising");
        oldDeviceConnected = deviceConnected;
    // connecting
    if (deviceConnected && !oldDeviceConnected) {
        // do stuff here on connecting
        Serial.println("Device Connected");
What exactly do you mean by that ?
