I have robot car with four dc encoder motor (jgb37-520 330rpm) and arduino with moebius motor driver for mega im trying to drive my robot for exact1m
im having issues for driving it to 1 meter exact if anyone know can help here is my code
#include <Encoder.h>
// Motor pin definitions
#define PWMA 12    // Motor A speed control
#define DIRA1 34   // Motor A direction control 1
#define DIRA2 35   // Motor A direction control 2
#define PWMB 8     // Motor B speed control
#define DIRB1 37   // Motor B direction control 1
#define DIRB2 36   // Motor B direction control 2
#define PWMC 6     // Motor C speed control
#define DIRC1 43   // Motor C direction control 1
#define DIRC2 42   // Motor C direction control 2
#define PWMD 5     // Motor D speed control
#define DIRD1 A4   // Motor D direction control 1
#define DIRD2 A5   // Motor D direction control 2
// Encoder pin definitions
#define ENCODER_A1 18
#define ENCODER_A2 31
#define ENCODER_B1 19
#define ENCODER_B2 38
#define ENCODER_C1 3
#define ENCODER_C2 49
#define ENCODER_D1 2
#define ENCODER_D2 48
// Constants
const double wheelDiameter = 0.08; // meters
const double wheelCircumference = wheelDiameter * 3.14159;
const int pulsesPerRevolution = 330 * 4; // 1:30 reduction and quadrature encoder
const double distancePerPulse = wheelCircumference / pulsesPerRevolution;
const double targetDistance = 1.0; // meters
const int MAX_MOTOR_SPEED = 150; // Reduced max motor speed
const int MIN_MOTOR_SPEED = 50; // Min motor speed to ensure it moves
const double slowdownThreshold = 0.5; // Distance to start slowing down (meters)
// Encoder objects
Encoder encoderA(ENCODER_A1, ENCODER_A2);
Encoder encoderB(ENCODER_B1, ENCODER_B2);
Encoder encoderC(ENCODER_C1, ENCODER_C2);
Encoder encoderD(ENCODER_D1, ENCODER_D2);
// Time variables
unsigned long startTime;
unsigned long lastTime;
unsigned long currentTime;
// Function prototypes
void setupMotors();
void runMotors(int speed);
void stopMotors();
void emergencyStop();
void taskCompletionNotification();
void checkForEmergencyStop();
void resetEncoders();
void ISR_A();
void ISR_B();
void ISR_C();
void ISR_D();
// Variables to keep track of encoder counts using interrupts
volatile long countA = 0;
volatile long countB = 0;
volatile long countC = 0;
volatile long countD = 0;
  setupMotors();
  // Attach interrupts for encoders
  attachInterrupt(digitalPinToInterrupt(ENCODER_A1), ISR_A, CHANGE);
  attachInterrupt(digitalPinToInterrupt(ENCODER_B1), ISR_B, CHANGE);
  attachInterrupt(digitalPinToInterrupt(ENCODER_C1), ISR_C, CHANGE);
  attachInterrupt(digitalPinToInterrupt(ENCODER_D1), ISR_D, CHANGE);
  // Reset encoder counts
  resetEncoders();
  // Calculate the number of ticks required to travel the target distance
  long targetTicks = targetDistance / distancePerPulse;
  Serial.print("Target Ticks: ");
  Serial.println(targetTicks);
  // Record the start time
  startTime = millis();
  // Run motors until the required number of ticks is reached
  while ((countA + countB + countC + countD) / 4 < targetTicks) {
    double currentDistance = calculateDistance((countA + countB + countC + countD) / 4);
    double remainingDistance = targetDistance - currentDistance;
    int motorSpeed = MAX_MOTOR_SPEED;
    if (remainingDistance <= slowdownThreshold) {
      motorSpeed = (int)(MAX_MOTOR_SPEED * (remainingDistance / slowdownThreshold));
      motorSpeed = constrain(motorSpeed, MIN_MOTOR_SPEED, MAX_MOTOR_SPEED);
    runMotors(motorSpeed);
    // Debugging output
    Serial.print("Current Ticks: ");
    Serial.print((countA + countB + countC + countD) / 4);
    Serial.print(" Distance: ");
    Serial.println(currentDistance);
    delay(20); // Reduce delay for higher control frequency
  // Stop motors once the target distance is reached
  stopMotors();
  // Record the end time
  unsigned long endTime = millis();
  unsigned long elapsedTime = endTime - startTime;
  Serial.print("Time taken: ");
  Serial.print(elapsedTime);
  Serial.println(" ms");
  while (true); // Halt execution
void setupMotors() {
  pinMode(PWMA, OUTPUT);
  pinMode(DIRA1, OUTPUT);
  pinMode(DIRA2, OUTPUT);
  pinMode(PWMB, OUTPUT);
  pinMode(DIRB1, OUTPUT);
  pinMode(DIRB2, OUTPUT);
  pinMode(PWMC, OUTPUT);
  pinMode(DIRC1, OUTPUT);
  pinMode(DIRC2, OUTPUT);
  pinMode(PWMD, OUTPUT);
  pinMode(DIRD1, OUTPUT);
  pinMode(DIRD2, OUTPUT);
void runMotors(int speed) {
  speed = constrain(speed, MIN_MOTOR_SPEED, MAX_MOTOR_SPEED);
  // Corrected direction for all motors
  analogWrite(PWMA, speed);
  digitalWrite(DIRA1, LOW);
  digitalWrite(DIRA2, HIGH);
  analogWrite(PWMB, speed);
  digitalWrite(DIRB1, HIGH);
  digitalWrite(DIRB2, LOW);
  analogWrite(PWMC, speed);
  digitalWrite(DIRC1, HIGH);
  digitalWrite(DIRC2, LOW);
  analogWrite(PWMD, speed);
  digitalWrite(DIRD1, LOW);
  digitalWrite(DIRD2, HIGH);
void stopMotors() {
  analogWrite(PWMA, 0);
  digitalWrite(DIRA2, LOW);
  analogWrite(PWMB, 0);
  digitalWrite(DIRB1, LOW);
  analogWrite(PWMC, 0);
  digitalWrite(DIRC1, LOW);
  analogWrite(PWMD, 0);
  digitalWrite(DIRD2, LOW);
double calculateDistance(long count) {
  return count * distancePerPulse;
void emergencyStop() {
  stopMotors();
  Serial.println("Emergency Stop Triggered!");
void taskCompletionNotification() {
  Serial.println("Task Completed: Robot has driven exactly 1 meter.");
void checkForEmergencyStop() {
  if (Serial.available()) {
    char ch = Serial.read();
    if (ch == 'e' || ch == 'E') {
      emergencyStop();
void resetEncoders() {
  countA = 0;
  countB = 0;
  countC = 0;
  countD = 0;
void ISR_A() {
  countA++;
void ISR_B() {
  countB++;
void ISR_C() {
  countC++;
void ISR_D() {
  countD++;
Please edit your post, select all code and click the <CODE/> button; next save your post. This will apply code tags (please read How to get the best out of this forum) which make the code easier to read and copy and the forum software will display it correctly.
Please describe the issues.
Thank you
i have a project of self driving car with lidar and motors just so first im trying to calculate distance and travel the robot to exact distance after that i want to try implementing PID control in robot
Please provide (links to) the datasheets for the motors and the driver board(s).
You still haven't described the issues that you have :wink:
issue im having that my target distance is 1 meter and my robot is driving for 2.4 meters. motor driver datasheet link GitHub - MoebiusTech/MecanumRobot-ArduinoMega2560: MecanumRobot-ArduinoMega2560
and Motor is JGB-37 520 12v dc encoder motor rpm 330 https://www.aliexpress.com/i/1005004490443526.html
How many pulses does the encoder output for 1 wheel rotation?
Is there any "slip" factor between wheels and the driving surface?
One approach would be to reduce targetTicks by a factor of 1.0/2.4
pulses the encoder outputs for one full rotation of the motor shaft it is 11.
there is no such thing but im using Yahboom Mecanum Wheel 80mm https://www.aliexpress.com/item/1005004266042624.html
okay i will try that
