I’m getting Sim 808 init error
I'm facing a quite contradictory problem.
When I run my program, it's saying "init sim error" but the D3 LED on my SIM808 is bipping every 5seconds(which means it has established the connection). Kinda weird.. Because I checked on a phone and my SIM is definitely unblocked,
Does somebody have a possible answer to this ?
In case, here is my program
  • Arduino | module
  • PIN_TX | TX1
  • PIN_RX | RX1
  • Power the module, which is successful when the power indicator on the module is ON
    // #define CONNECT_BY_JUMPER 1
    #if CONNECT_BY_JUMPER
    #define PIN_TX 7
    #define PIN_RX 8
    SoftwareSerial mySerial(PIN_TX, PIN_RX);
    DFRobot_SIM808 sim808(&mySerial);
  • Use Leonardo for push-in connection
  • Set DIP switch to 3-Arduino, and use the Serial1 of Leonardo for communication
    #elif defined(ARDUINO_AVR_LEONARDO)
    DFRobot_SIM808 sim808(&Serial1);
  • Use UNO & MEGA2560 for push-in connection
  • Set DIP switch to 3-Arduino, and use the Serial of UNO and MEGA2560 for communication
    #else
    DFRobot_SIM808 sim808(&Serial);
    #endif
//Mobile phone number,need to change
#define PHONE_NUMBER "009665******15"
//The content of messages sent
#define MESSAGE "hello,world"
mySerial.begin(9600);
Serial1.begin(9600);
#endif
//******** Initialize sim808 module *************
while(!sim808.init()) {
Serial.print("Sim808 init error\r\n");
Serial.println("Sim808 init success");
Serial.println("Start to send message ...");
//******** define phone number and text **********
sim808.sendSMS((char *)PHONE_NUMBER, (char *)MESSAGE);
//nothing to do
Tx to Tx is wrong! One Tx must be connected to Rx of the receiver and vice vers.
What about the powering?
Schematics would make the suggestions better. Guesses are..... guesses, often wrong.
You need to be better at cleaning up the code after copy/paste from HTML.
    Arduino | module
    PIN_TX | TX1
    PIN_RX | RX1
#define PIN_TX 7
#define PIN_RX 8
#else
#endif
// Mobile phone number,need to change
// The content of messages sent
#endif
  while (!sim808.init()) {
  // nothing to do
