I need a flight controller for fixed-wing RC aircraft
Hi everybody!
I find lots of examples for quadcopters, but what I want to build is a flight controller that will work as in those models that come RTF (ready to fly) with the gyros and accelerometers already installed, (they are known as SAFE in Spektrum world). It should limit the yaw, pitch and roll angles and stabilize the model in flight (against wind and turbulence).
As far as I know, I can use a Nano and a MPU6050 board, and of course with the appropriate sketch. Using a channel from the transmitter, I should be able to engage or disengage option.
Are there examples of what I need?
Thanks!
Using my favorite search engine I find lots of stuff but I do not know enough about what you want to determine if it is applicable to your project.I did find some COTS (Commercial Off The Shelf) units.
I played with this back in 2020 and flew it with a combat delta with elevons.
I used a promini with a MPU6050 on it's back and connected a PPM receiver to it.
I also used some libraries by RC-Navy to read the PPM stream and output the servo signals
you can find them here:
I think this code was the last version I flew with. I added a gain slider to adjust sensitivity in flight because with high gain settings I suffered from oscillations on the elevator.
I also added dynamic gain to have more stabilization around stick center and no stabilization when full up-down or left-right.
That worked better in aircombats.
Be sure to add an extra elco (470UF) between GND and VCC, or you will suffer from lockups in flight. I must have the hardware somewhere and could make a picture how I rigged it up.
It's definitely fun. good luck.
   https://www.youtube.com/watch?v=H7Ph6sIjl98&feature=youtu.be
#define ELEVON_MIXING        // comment out if elevon mixing routine is NOT required.
#define AUX_GAIN               // comment out if no gain setting required via sliders
//#define DYNAMIC_GAIN           // comment out for constant gyro gain
#include <Wire.h>
#define CALIBRATION_COUNT      200
#define MPU6050_I2C_ADDRESS    0x68
#define MPU6050_PWR_MGMT_1     0x6B   // R/W
#define GYRO_ADDRESS           0x68
#define GYRO_VALUES_REGISTER   0x43
#define GYRO_HIGH_BYTE_FIRST
// Set the order in which the gyro values are read
#define GYRO_AXIS_1    gyro_pitch
#define GYRO_AXIS_2    gyro_roll
#define GYRO_AXIS_3    gyro_yaw
// Set a value of -1 for gyro axes that should be reversed
#define GYRO_INVERT_PITCH   1
#define GYRO_INVERT_ROLL    1
#define GYRO_INVERT_YAW     1
// Set a value of -1 for RC input axes that should be reversed
#define RC_INVERT_PITCH      1
#define RC_INVERT_ROLL       1
#define RC_INVERT_YAW        1
#define PITCH_RATE           100   // adjust to make servos move max range with tx control
#define ROLL_RATE            100   // adjust to make servos move max range with tx control
#define YAW_RATE             100   // adjust to make servos move max range with tx control
#define MIN_SERVO_PULSE      800
#define MAX_SERVO_PULSE      2200
#define RC_CHANS            6
#define ROLL_CHANNEL        1
#define PITCH_CHANNEL       2
#define THROTTLE_CHANNEL    3
#define YAW_CHANNEL         4
#define AUX1_CHANNEL        5
#define AUX2_CHANNEL        6
#include <SoftRcPulseOut.h>
#define SERVO1_PIN              11
#define SERVO2_PIN              12
#define SERVO3_PIN              13
#define SERVO4_PIN              14
#define NEUTRAL_US              1500 /* Default position in case of no pulse at startup */
#define NOW                     1
enum {AILERON = 0, ELEVATOR, THROTTLE, RUDDER, SERVO_NB}; /* Trick: use an enumeration to declare the index of the servos AND the amount of servos */
SoftRcPulseOut ServoMotor[SERVO_NB]; /* Table Creation for SERVO_NB objects of SoftRcPulseOut type */
int servoVal3; // only throttle needs defined here (compilation error if defined in loop)
#include <TinyPpmReader.h>
#define PPM_INPUT_PIN  10
#define CHANNEL_NB     6 // does not work with 8 on stormRC receiver
float pid_p_gain_roll = 1.0;               //Gain setting for the roll P-controller (1.3)
float pid_i_gain_roll = 0.0;               //Gain setting for the roll I-controller (0.05)
float pid_d_gain_roll = 1.0;               //Gain setting for the roll D-controller (15)
int   pid_max_roll = 400;                  //Maximum output of the PID-controller (+/-)
float pid_p_gain_pitch = 1.0;              //Gain setting for the pitch P-controller.
float pid_i_gain_pitch = 0.0;              //Gain setting for the pitch I-controller.
float pid_d_gain_pitch = 1.0;              //Gain setting for the pitch D-controller.
int pid_max_pitch = 400;                   //Maximum output of the PID-controller (+/-)
float pid_p_gain_yaw = 0.0;                //Gain setting for the pitch P-controller. //4.0
float pid_i_gain_yaw = 0.0;                //Gain setting for the pitch I-controller. //0.02
float pid_d_gain_yaw = 0.0;                //Gain setting for the pitch D-controller.
int pid_max_yaw = 400;                     //Maximum output of the PID-controller (+/-)
int pid_max_yaw_i = 100;                   //Maximum value of I term of the PID-controller (+/-)
float gyro_roll_cal, gyro_pitch_cal, gyro_yaw_cal;
float gyro_pitch, gyro_roll, gyro_yaw;
float gyro_roll_input, gyro_pitch_input, gyro_yaw_input;
int receiver_input_roll, receiver_input_pitch, receiver_input_throttle, receiver_input_yaw;
float pid_i_mem_roll, pid_roll_setpoint, pid_output_roll, pid_last_roll_d_error;
float pid_i_mem_pitch, pid_pitch_setpoint, pid_output_pitch, pid_last_pitch_d_error;
float pid_i_mem_yaw, pid_yaw_setpoint, pid_output_yaw, pid_last_yaw_d_error;
  delay(5); //wait for the capacitor to charge and vcc stabilization
  i2c_write_reg(GYRO_ADDRESS, 0x6B, 0x80);  //PWR_MGMT_1    -- DEVICE_RESET 1
  delay(5); // wait for the sensor to reset
  i2c_write_reg(GYRO_ADDRESS, 0x6B, 0x03);  //PWR_MGMT_1    -- SLEEP 0; CYCLE 0; TEMP_DIS 0; CLKSEL 3 (PLL with Z Gyro reference)
  i2c_write_reg(GYRO_ADDRESS, 0x1A, 0);     //CONFIG        -- EXT_SYNC_SET 0 (disable input pin for data sync) ; default DLPF_CFG = 0 => ACC bandwidth = 260Hz  GYRO bandwidth = 256Hz)
  i2c_write_reg(GYRO_ADDRESS, 0x1B, 0x08);  //GYRO_CONFIG   -- FS_SEL = 3: Full scale set to 500 deg/sec
  // Clear the 'sleep' bit to start the sensor.
  MPU6050_write_reg (MPU6050_PWR_MGMT_1, 0);
  delay(1); // wait for the sensor to startup
  gyro_pitch_cal = 0;
  gyro_roll_cal = 0;
  gyro_yaw_cal = 0;
  for (int i = 0; i < CALIBRATION_COUNT ; i++) {
    gyro_read_raw();                                           //Read the gyro output.
    gyro_pitch_cal += gyro_pitch;                              //Add pitch value to gyro_pitch_cal.
    gyro_roll_cal  += gyro_roll;                               //Add roll value to gyro_roll_cal.
    gyro_yaw_cal   += gyro_yaw;                                //Add yaw value to gyro_yaw_cal.
    delay(1);                                   //Wait one milliseconds before the next loop.
  //Now that we have samples, we need to divide by the sample count to get the average gyro offset.
  gyro_pitch_cal /= CALIBRATION_COUNT;
  gyro_roll_cal  /= CALIBRATION_COUNT;
  gyro_yaw_cal   /= CALIBRATION_COUNT;
  //Configure servo pins as output.
  ServoMotor[AILERON].attach(SERVO1_PIN);   /* enumeration is used a index for the ServoMotor[] table */
  ServoMotor[ELEVATOR].attach(SERVO2_PIN);   /* enumeration is used a index for the ServoMotor[] table */
  ServoMotor[THROTTLE].attach(SERVO3_PIN);   /* enumeration is used a index for the ServoMotor[] table */
  ServoMotor[RUDDER].attach(SERVO4_PIN);   /* enumeration is used a index for the ServoMotor[] table */
  TinyPpmReader.attach(PPM_INPUT_PIN); /* Attach TinyPpmReader to PPM_INPUT_PIN pin */
 float rollStabMagnitude;
 float pitchStabMagnitude;
  static uint16_t Width_us = NEUTRAL_US; /* Static to keep the value at the next loop */
  //Let's get the current gyro data and scale it to degrees per second for the pid calculations.
  gyro_read_raw();
  gyro_pitch -= gyro_pitch_cal; // apply calibration
  gyro_roll  -= gyro_roll_cal;
  gyro_yaw   -= gyro_yaw_cal;
  gyro_pitch *= GYRO_INVERT_PITCH / 57.14286;   //Gyro pid input is deg/sec. gyro_apply_inversion_and_scale
  gyro_roll  *= GYRO_INVERT_ROLL / 57.14286;    //Gyro pid input is deg/sec.
  gyro_yaw   *= GYRO_INVERT_YAW / 57.14286;     //Gyro pid input is deg/sec.
  float uptake = 0.2;  //0.2
  float oneMinusUptake = 1 - uptake;
  gyro_pitch_input = (gyro_pitch_input * oneMinusUptake) + (gyro_pitch * uptake);
  gyro_roll_input  = (gyro_roll_input * oneMinusUptake)  + (gyro_roll * uptake);
  gyro_yaw_input   = (gyro_yaw_input * oneMinusUptake)   + (gyro_yaw * uptake);
#ifdef AUX_GAIN
  // gain setting via AUX channels
  rollStabMagnitude  = (constrain((float)TinyPpmReader.width_us(AUX1_CHANNEL) - 1000, 0, 1000)) / 1000.0f;
  pitchStabMagnitude = (constrain((float)TinyPpmReader.width_us(AUX2_CHANNEL) - 1000, 0, 1000)) / 1000.0f;
  gyro_roll_input *= rollStabMagnitude;
  gyro_pitch_input *= pitchStabMagnitude;
#endif
#ifdef DYNAMIC_GAIN
  // Dynamic gain setting
  // stick center is 1 and at both end-points = 0 , like this curve /\
  // so stabilization magnitude is max at centerstick and zero at full stick
  rollStabMagnitude  = (500 - fabs(constrain((float)TinyPpmReader.width_us(ROLL_CHANNEL) - 1500, -500, 500))) / 500.0f  ;
  pitchStabMagnitude  = (500 - fabs(constrain((float)TinyPpmReader.width_us(PITCH_CHANNEL) - 1500, -500, 500))) / 500.0f  ;
#endif // end dynamic gain
  if ((TinyPpmReader.detectedChannelNb() >= CHANNEL_NB) && TinyPpmReader.isSynchro()) {
    pid_roll_setpoint  = RC_INVERT_ROLL  * ((float)TinyPpmReader.width_us(ROLL_CHANNEL) - 1500.0f);
    pid_pitch_setpoint = RC_INVERT_PITCH * ((float)TinyPpmReader.width_us(PITCH_CHANNEL) - 1500.0f);
    servoVal3 = TinyPpmReader.width_us(THROTTLE_CHANNEL);
    pid_yaw_setpoint   = RC_INVERT_YAW   * ((float)TinyPpmReader.width_us(YAW_CHANNEL) - 1500.0f);
  //The PID set point in degrees per second is determined by the receiver input.
  pid_pitch_setpoint *= PITCH_RATE / 100;
  pid_roll_setpoint  *= ROLL_RATE / 100;
  pid_yaw_setpoint   *= YAW_RATE / 100;
  //PID inputs are known. So we can calculate the pid output.
  float pid_error_temp;
  //Pitch calculations
  pid_error_temp = gyro_pitch_input - pid_pitch_setpoint;
  pid_i_mem_pitch += pid_i_gain_pitch * pid_error_temp;
  pid_i_mem_pitch = constrain(pid_i_mem_pitch, -pid_max_pitch, pid_max_pitch);
  pid_output_pitch = pid_p_gain_pitch * pid_error_temp + pid_i_mem_pitch + pid_d_gain_pitch * (pid_error_temp - pid_last_pitch_d_error);
  pid_output_pitch = constrain(pid_output_pitch, -pid_max_pitch, pid_max_pitch);
  pid_last_pitch_d_error = pid_error_temp;
  //Roll calculations
  pid_error_temp = gyro_roll_input - pid_roll_setpoint;
  pid_i_mem_roll += pid_i_gain_roll * pid_error_temp;
  pid_i_mem_roll = constrain(pid_i_mem_roll, -pid_max_roll, pid_max_roll);
  pid_output_roll = pid_p_gain_roll * pid_error_temp + pid_i_mem_roll + pid_d_gain_roll * (pid_error_temp - pid_last_roll_d_error);
  pid_output_roll = constrain(pid_output_roll, -pid_max_roll, pid_max_roll);
  pid_last_roll_d_error = pid_error_temp;
  //Yaw calculations
  pid_error_temp = gyro_yaw_input - pid_yaw_setpoint;
  pid_i_mem_yaw += pid_i_gain_yaw * pid_error_temp;
  pid_i_mem_yaw = constrain(pid_i_mem_yaw, -pid_max_yaw_i, pid_max_yaw_i);
  pid_output_yaw = pid_p_gain_yaw * pid_error_temp + pid_i_mem_yaw + pid_d_gain_yaw * (pid_error_temp - pid_last_yaw_d_error);
  pid_output_yaw = constrain(pid_output_yaw, -pid_max_yaw, pid_max_yaw);
  pid_last_yaw_d_error = pid_error_temp;
  int servoVal1 = pid_output_roll;
  int servoVal2 = pid_output_pitch;
  int servoVal4 = pid_output_yaw;
#ifdef ELEVON_MIXING // elevon mixing required
  int leftServo =   servoVal1 - servoVal2;
  int rightServo =  servoVal1 + servoVal2;
  servoVal1 = leftServo;
  servoVal2 = rightServo;
#endif // end elevon mixing
  servoVal1 += 1500;
  servoVal2 += 1500;
  servoVal4 += 1500;
  servoVal1 = constrain(servoVal1, MIN_SERVO_PULSE, MAX_SERVO_PULSE);
  servoVal2 = constrain(servoVal2, MIN_SERVO_PULSE, MAX_SERVO_PULSE);
  servoVal4 = constrain(servoVal4, MIN_SERVO_PULSE, MAX_SERVO_PULSE);
  ServoMotor[AILERON].write_us(servoVal1);
  ServoMotor[ELEVATOR].write_us(servoVal2);
  ServoMotor[THROTTLE].write_us(servoVal3);
  ServoMotor[RUDDER].write_us(servoVal4);
  SoftRcPulseOut::refresh();
} //end loop
// MPU6050_write
// This is a common function to write multiple bytes to an I2C device.
// If only a single register is written,
// use the function MPU_6050_write_reg().
// Parameters:
//   start : Start address, use a define for the register
//   pData : A pointer to the data to write.
//   size  : The number of bytes to write.
// If only a single register is written, a pointer
// to the data has to be used, and the size is
// a single byte:
//   int data = 0;        // the data to write
//   MPU6050_write (MPU6050_PWR_MGMT_1, &c, 1);
int MPU6050_write(int start, const uint8_t *pData, int size)
  int n, error;
  Wire.beginTransmission(MPU6050_I2C_ADDRESS);
  n = Wire.write(start);        // write the start address
  if (n != 1)
    return (-20);
  n = Wire.write(pData, size);  // write data bytes
  if (n != size)
    return (-21);
  error = Wire.endTransmission(true); // release the I2C-bus
  if (error != 0)
    return (error);
  return (0);         // return : no error
// MPU6050_write_reg
// An extra function to write a single register.
// It is just a wrapper around the MPU_6050_write()
// function, and it is only a convenient function
// to make it easier to write a single register.
int MPU6050_write_reg(int reg, uint8_t data)
  int error;
  error = MPU6050_write(reg, &data, 1);
  return (error);
void i2c_write_reg(int address, byte reg, byte val) {
  Wire.beginTransmission(address);
  Wire.write(reg);
  Wire.write(val);
// Requires open I2C transmission with two bytes available
int gyro_read_int() {
  byte highByte = Wire.read();
  byte lowByte = Wire.read();
  return (highByte << 8) | lowByte;
void gyro_read_raw() {
  Wire.beginTransmission(GYRO_ADDRESS);                        //Start communication with the gyro
  Wire.write(GYRO_VALUES_REGISTER);                            //Start reading and auto increment with every read
  Wire.endTransmission();                                      //End the transmission
  Wire.requestFrom(GYRO_ADDRESS, 6);                           //Request 6 bytes from the gyro
  while (Wire.available() < 6);                                //Wait until the 6 bytes are received
  GYRO_AXIS_1 = gyro_read_int();
  GYRO_AXIS_2 = gyro_read_int();
  GYRO_AXIS_3 = gyro_read_int();
The youtube is not mine. It's the source where I started from initially.
Thank you hmeijdan!
I will not play with combat delta with elevons, just have some relaxing fan flying trainers, I just want to add stabilization to anu model so anyone can fly it.
So far I managed to read PPM channels from a FlySky receiver.
I guess that limiting the yaw, pitch and roll angles would be the easier part, but stabilizing in flight will be another story.
Thanks again!
