I need help because my lcd 16×2 screen with i2c module isn't working properly
My LCD Display is not working properly. Need help urgently. I have tried everything. Need help urgently.
It might help if you provide details.
  1. Description of the problem.
    • Does the problem also happen with example code.
  2. Your code, posted using code tags as described in https://forum.arduino.cc/t/how-to-get-the-best-out-of-this-forum/679966#posting-code-and-common-code-problems.
    • If you get errors during compilation or upload, post them here (again using code tags).
  3. Wiring diagram / schematic.
    • Components should be easy to identify (all names and values).
    • The wiring should be complete including all power.
Please read and use this link: How to get the best out of this forum - Projects / General Guidance - Arduino Forum
Without any information no help can be given.
Problem is that the texts don't show. Blocks appear. When adjusted with a potentiometer, the blocks disappear but the text never comes in. I am using an Arduino Uno. 4 jumper wires. I tried everything on yt and tutorials but no one helped. Address of lcd is 0×27. I2c is soldered properly. Still no text
It seems you didn’t understand the messages from @Railroader and @sterretje .
I think they provided the perfect answers to speed up the resolution.
The sooner you follow the hints, the sooner you’ll resolve your issue. :-)
Have you confirmed that with i2c scanner?
You are the one not helping by not answering questions from people trying to help.
Usually the I2C backpack board arrives pre-soldered to the LCD pins. Show good pictures of your soldering the I2C backpack to the LCD.
I understand your frustration. Can you share the LCD model, connection type, and exactly what’s happening so I can help troubleshoot?
You would help yourself (to produce your chatGPT answer) by reading the thread, starting from the title.
Explained in the title and Post #1.
Explained in Post #4.
Hi, @krish112
Welcome to the forum.
Can you please post a circuit diagram of your project, including power supplies, use a pen(cil) and paper and show an image of it would be fine.
Can you post some images of your project?
So we can see your component layout.
Thanks... Tom.... :smiley: :+1: :coffee: :australia:
Thank you for your suggestion! I actually wrote my reply myself and made sure to read the entire post and all related comments before commenting. I really appreciate your input.
Nope. You repeated previous questions.
