I need help create a code stop the 7 segment from counting down when it hit 0
I am new to coding Arduino Java and don't know how to code a countdown that will stop automatic when it hit 0 I am using 4 digital display with Arduino heres the code.
// Heres my actual 4 digital display board
//My Code
// DEFINES
// Macros to retrieve the fractional seconds and minute parts of a time
// supplied in ms
#define numberOfSeconds(time) ((time / 1000) % 60)
#define numberOfMinutes(time) (((time / 1000) / 60) % 60)
// INCLUDES
// GitHub - avishorp/TM1637: Arduino library for TM1637 (LED Driver)
#include <TM1637Display.h>
// CONSTANTS
const uint8_t OFF[] = {0, 0, 0, 0};
// In this library, the byte order is .GFEDCBA
const uint8_t PLAY[] = {B01110011, B00111000, B01011111, B01101110};
// GLOBALS
// Create a display object, specifying parameters (Clock pin, Data pin)
TM1637Display display(2, 3);
// 1000ms in 1sec, 60secs in 1min, 60mins in 1hr. So, 1000x60x60 = 3600000ms = 1hr
unsigned long timeLimit = 3600000;
void setup(){
// Set brightness
display.setBrightness(0x0c);
// Clear the display
display.setSegments(OFF);
void countdown() {
// Calculate the time remaining
unsigned long timeRemaining = timeLimit - millis();
while(timeRemaining > 0) {
// To display the countdown in mm:ss format, separate the parts
int seconds = numberOfSeconds(timeRemaining);
int minutes = numberOfMinutes(timeRemaining);
// This displays the seconds in the last two places
display.showNumberDecEx(seconds, 0, true, 2, 2);
// Display the minutes in the first two places, with colon
display.showNumberDecEx(minutes, 0x80>>3, true, 2, 0);
// Update the time remaining
void displayText() {
display.setSegments(PLAY);
delay(2000);
void loop(){
//displayText();
countdown();
Don't think of it as Java (because it isn't), think of it as C++ (because that's what it is).
This may help.
