I just put a demo pattern in my timer1 interrupt service routine. But, it takes too much time from my Arduino. I can't even print to the serial monitor. I think the interval time is too high. What would be a suitable interval time, and if that is not the problem, I would like to know what it is.
Code:
24 x 5 led matrix
Version 2.2
by: ArduMasterPro44
const uint8_t alphabet[95][4] = {
{ 3, 0x00, 0x00, 0x00 }, // " "
{ 1, 0x17, 0x00, 0x00 }, // "!"
{ 3, 0x03, 0x00, 0x03 }, // """
{ 3, 0x1F, 0x0A, 0x1F }, // "#"
{ 3, 0x0B, 0x1F, 0x0D }, // "$"
{ 3, 0x19, 0x04, 0x13 }, // "%"
{ 3, 0x0A, 0x15, 0x1A }, // "&"
{ 1, 0x03, 0x00, 0x00 }, // "'"
{ 2, 0x0E, 0x11, 0x00 }, // "("
{ 2, 0x11, 0x0E, 0x00 }, // ")"
{ 3, 0x05, 0x02, 0x05 }, // "*"
{ 3, 0x04, 0x0E, 0x04 }, // "+"
{ 1, 0x18, 0x00, 0x00 }, // ","
{ 3, 0x04, 0x04, 0x04 }, // "-"
{ 1, 0x10, 0x00, 0x00 }, // "."
{ 3, 0x18, 0x04, 0x03 }, // "/"
{ 3, 0x1F, 0x11, 0x1F }, // "0"
{ 3, 0x12, 0x1F, 0x10 }, // "1"
{ 3, 0x19, 0x15, 0x12 }, // "2"
{ 3, 0x11, 0x15, 0x1F }, // "3"
{ 3, 0x07, 0x04, 0x1F }, // "4"
{ 3, 0x17, 0x15, 0x1D }, // "5"
{ 3, 0x1E, 0x15, 0x1D }, // "6"
{ 3, 0x01, 0x01, 0x1F }, // "7"
{ 3, 0x1F, 0x15, 0x1F }, // "8"
{ 3, 0x17, 0x15, 0x1F }, // "9"
{ 1, 0x0A, 0x00, 0x00 }, // ":"
{ 1, 0x1A, 0x00, 0x00 }, // ";"
{ 3, 0x04, 0x0A, 0x11 }, // "<"
{ 3, 0x0A, 0x0A, 0x0A }, // "="
{ 3, 0x11, 0x0A, 0x04 }, // ">"
{ 3, 0x01, 0x15, 0x03 }, // "?"
{ 3, 0x0E, 0x11, 0x17 }, // "@"
{ 3, 0x1F, 0x05, 0x1F }, // "A"
{ 3, 0x1F, 0x15, 0x1B }, // "B"
{ 3, 0x1F, 0x11, 0x11 }, // "C"
{ 3, 0x1F, 0x11, 0x0E }, // "D"
{ 3, 0x1F, 0x15, 0x11 }, // "E"
{ 3, 0x1F, 0x05, 0x01 }, // "F"
{ 3, 0x1F, 0x11, 0x1D }, // "G"
{ 3, 0x1F, 0x04, 0x1F }, // "H"
{ 3, 0x11, 0x1F, 0x11 }, // "I"
{ 3, 0x18, 0x10, 0x1F }, // "J"
{ 3, 0x1F, 0x04, 0x1B }, // "K"
{ 3, 0x1F, 0x10, 0x10 }, // "L"
{ 3, 0x1F, 0x06, 0x1F }, // "M"
{ 3, 0x1F, 0x01, 0x1F }, // "N"
{ 3, 0x1F, 0x11, 0x1F }, // "O"
{ 3, 0x1F, 0x05, 0x07 }, // "P"
{ 3, 0x0F, 0x19, 0x0F }, // "Q"
{ 3, 0x1F, 0x05, 0x1A }, // "R"
{ 3, 0x17, 0x15, 0x1D }, // "S"
{ 3, 0x01, 0x1F, 0x01 }, // "T"
{ 3, 0x1F, 0x10, 0x1F }, // "U"
{ 3, 0x0F, 0x10, 0x1F }, // "V"
{ 3, 0x1F, 0x0C, 0x1F }, // "W"
{ 3, 0x1B, 0x04, 0x1B }, // "X"
{ 3, 0x07, 0x1C, 0x07 }, // "Y"
{ 3, 0x19, 0x15, 0x13 }, // "Z"
{ 2, 0x1F, 0x11, 0x00 }, // "["
{ 3, 0x03, 0x04, 0x18 }, // "\"
{ 2, 0x11, 0x1F, 0x00 }, // "]"
{ 3, 0x02, 0x01, 0x02 }, // "^"
{ 3, 0x10, 0x10, 0x10 }, // "_"
{ 2, 0x01, 0x02, 0x00 }, // "`"
{ 3, 0x0c, 0x12, 0x1E }, // "a"
{ 3, 0x1F, 0x12, 0x0C }, // "b"
{ 3, 0x1E, 0x12, 0x12 }, // "c"
{ 3, 0x0C, 0x12, 0x1F }, // "d"
{ 3, 0x0C, 0x1A, 0x14 }, // "e"
{ 3, 0x04, 0x1F, 0x05 }, // "f"
{ 3, 0x12, 0x15, 0x0E }, // "g"
{ 3, 0x1F, 0x04, 0x18 }, // "h"
{ 1, 0x1D, 0x00, 0x00 }, // "i"
{ 2, 0x10, 0x0D, 0x00 }, // "j"
{ 3, 0x1F, 0x04, 0x1A }, // "k"
{ 1, 0x1F, 0x00, 0x00 }, // "l"
{ 3, 0x1E, 0x04, 0x1E }, // "m"
{ 3, 0x1E, 0x02, 0x1E }, // "n"
{ 3, 0x1E, 0x12, 0x1E }, // "o"
{ 3, 0x1F, 0x09, 0x06 }, // "p"
{ 3, 0x06, 0x09, 0x1F }, // "q"
{ 3, 0x1E, 0x02, 0x04 }, // "r"
{ 3, 0x14, 0x16, 0x0A }, // "s"
{ 3, 0x02, 0x0F, 0x12 }, // "t"
{ 3, 0x1E, 0x10, 0x1E }, // "u"
{ 3, 0x0E, 0x10, 0x0E }, // "v"
{ 3, 0x1E, 0x08, 0x1E }, // "w"
{ 3, 0x1A, 0x04, 0x1A }, // "x"
{ 3, 0x17, 0x14, 0x0F }, // "y"
{ 3, 0x1A, 0x12, 0x16 }, // "z"
{ 3, 0x04, 0x1F, 0x11 }, // "{"
{ 1, 0x1F, 0x00, 0x00 }, // "|"
{ 3, 0x11, 0x1F, 0x04 }, // "}"
{ 3, 0x04, 0x0C, 0x08 } // "~"
const uint8_t Data1 = 3;
const uint8_t Clock1 = 4;
const uint8_t Data2 = 5;
const uint8_t Clock2 = 6;
const uint8_t Latch = 7;
const uint16_t delayTime = 125;
const uint8_t rows = 24;
const uint8_t columns = 5;
uint32_t time;
char message[] = "Aaaaaaaaaaaaaaaaaaaaaaaaa";
int16_t size = 0;
uint16_t length = strlen(message);
uint8_t* bitMap;
volatile uint8_t displayBuffer[rows] = {
0x01,
0x02,
0x04,
0x08,
0x10,
0x08,
0x04,
0x02,
0x01,
0x02,
0x04,
0x08,
0x10,
0x08,
0x04,
0x02,
0x01,
0x02,
0x04,
0x08,
0x10,
0x08,
0x04,
0x02
// Uncomment to use pinMode() / comment to use data direction register
// pinMode(Data1, OUTPUT);
// pinMode(Clock1, OUTPUT);
// pinMode(Data2, OUTPUT);
// pinMode(Clock2, OUTPUT);
// pinMode(Latch, OUTPUT);
// Comment to use pinMode() / uncomment to use data direction register
DDRD |= B11111000;
DDRB |= (1 << PB5);
// ──────── Timer configuration ────────┐
// Reset Timer1 Control Reg A │
TCCR1A = 0; // ────────────────────────┤
// Set CTC mode │
TCCR1B &= ~(1 << WGM13); // ───────────┤
TCCR1B |= (1 << WGM12); // ───────────┤
// Set to prescaler of 1 │
TCCR1B &= ~(1 << CS12); // ───────────┤
TCCR1B &= ~(1 << CS11); // ───────────┤
TCCR1B |= (1 << CS10); // ───────────┤
// Reset Timer1 a and set compare value │
TCNT1 = 0; // ───────────┤
OCR1A = 4000; // ───────────┤
// Enable Timer1 compare interrupt │
TIMSK1 = (1 << OCIE1A); // ───────────┤
// Enable global interrupts │
sei(); // ───────────┘
for (uint16_t i = 0; i < length; i++) { // Loop for every character in the message
size += alphabet[message[i] - 32][0];
if (i < length - 1) { // Check if it isn't the last character of the message
size++;
bitMap = new uint8_t[size];
uint16_t x = 0; // Keeps track of the X-Axis bit
for (uint8_t j = 0; j < alphabet[message[i] - 32][0]; j++) { // Loop for every byte in the character
bitMap[x] = alphabet[message[i] - 32][j + 1]; // Store the byte in the bitMap[] array
x++;
bitMap[x] = 0; // Store a 0x00 byte in the bitMap[] array
x++;
// int16_t i = -24;
// while (i < size) {
// if (millis() - time >= delayTime) {
// i++;
// time = millis();
// shiftText(i, rows, columns);
PORTB ^= (1 << 5);
Serial.println("Good");
void shiftText(int16_t idx, uint8_t bitsX, uint8_t bitsY) {
for (uint8_t i = 0; i < bitsX; i++) {
digitalWrite(Latch, LOW);
if (i == 0) {
digitalWrite(Data1, HIGH);
digitalWrite(Clock1, HIGH);
digitalWrite(Clock1, LOW);
digitalWrite(Data1, LOW);
shiftBits(Data2, Clock2, LSBFIRST, ~stringToChar(i + idx), bitsY);
digitalWrite(Latch, HIGH); // Shift the byte to the matrix
uint8_t stringToChar(int16_t bit) { // Converts one peice of the character according to the bit variable
if (bit >= size) {
return 0x00;
} else if (bit < 0) {
return 0x00;
return bitMap[bit];
void shiftBits(uint8_t data, uint8_t clock, uint8_t bitOrder, uint32_t value, uint8_t bits) {
for (uint8_t i = 0; i < bits; i++) {
if (bitOrder == LSBFIRST) {
digitalWrite(data, value & 1);
value >>= 1;
} else if (bitOrder == MSBFIRST) {
digitalWrite(data, (value & bit(bits - 1)) != 0);
value <<= 1;
digitalWrite(clock, HIGH);
digitalWrite(clock, LOW);
ISR(TIMER1_COMPA_vect) {
for (uint8_t i = 0; i < rows; i++) {
PORTD &= ~(1 << Latch);
if (i == 0) {
PORTD |= (1 << Data1);
PORTD |= (1 << Clock1);
PORTD &= ~(1 << Clock1);
PORTD &= ~(1 << Data1);
shiftBits(Data2, Clock2, LSBFIRST, ~displayBuffer[i], columns);
PORTD |= (1 << Latch); // Shift the byte to the matrix
