I need help with Arduino IDE adding adxl345 to my current code
I have got this problem I am doing school project in arduino this is my like 3rd project first 3 were much easier now I am doing "black box" or Flight data recording I am using Arduino Uno, Breadboard, Neo-6M GPS, BMP280 and adxl345 and MicroSD card module. I have functioning code with everything when I am using code without adxl345 sensor. This code that I provide does work perfectly it basically measures all the data that I have in code and puts into the table. Code:
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <SD.h>
#include <Wire.h>
#include <Adafruit_BMP280.h>
static const int RXPin = 4, TXPin = 3; // Change these pins according to your setup
static const uint32_t GPSBaud = 9600;
File dataFile;
unsigned long lastSaveTime = 0; // Variable to keep track of the last time data was saved
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
// Create an instance of BMP280 sensor
Adafruit_BMP280 bmp280;
  ss.begin(GPSBaud);
  // Initialize SD card
  if (!SD.begin(10))
    Serial.println("SD Card initialization failed!");
    return;
  // Initialize BMP280 sensor
  if (!bmp280.begin(0x76))
    Serial.println("Could not find a valid BMP280 sensor, check wiring!");
    while (1);
  while (ss.available() > 0)
    if (gps.encode(ss.read()))
      saveLocation();
  // Check if it's time to save the data
  if (millis() - lastSaveTime >= 5000)
    if (saveLocation()) { // Save sensor data to SD card and print message if successful
      Serial.println("Data has been written");
    lastSaveTime = millis(); // Update the last save time
  delay(100); // Add a short delay to prevent excessive CPU usage
bool saveLocation()
  // Open the data file in write mode
  dataFile = SD.open("gps_data.txt", FILE_WRITE);
  if (dataFile)
    // Write headers to the file if the file is empty
    if (dataFile.size() == 0) {
      dataFile.println("Latitude\tLongitude\tTemperature (C)\tPressure (hPa)\tAltitude (m)");
    // Write data to the file
    dataFile.print(gps.location.lat(), 6);
    dataFile.print("\t");
    dataFile.print(gps.location.lng(), 6);
    dataFile.print(bmp280.readTemperature(), 2); // 2 decimal places for temperature
    dataFile.print("\t\t"); // Leave space for Pressure and Altitude
    dataFile.print(bmp280.readPressure() / 100.0, 2); // Convert Pa to hPa, 2 decimal places for pressure
    dataFile.println(bmp280.readAltitude(1013.25), 2); // Use sea level pressure for altitude calculation, 2 decimal places for altitude
    // Close the file
    dataFile.close();
    // Print to Serial in table format
    Serial.print(gps.location.lat(), 6);
    Serial.print("\t");
    Serial.print(gps.location.lng(), 6);
    Serial.print("\t");
    Serial.print(bmp280.readTemperature(), 2);
    Serial.print("\t");
    Serial.print(bmp280.readPressure() / 100.0, 2);
    Serial.print("\t");
    Serial.println(bmp280.readAltitude(1013.25), 2);
    return true; // Return true indicating successful write
    Serial.println("Error opening data file!");
    return false; // Return false indicating failure
As soon as I add code with adxl345 so it measures X,Y,Z acceleration it doesnt print anything to serial other then "Error opening data file!". I need to assume that something wrong is in the code becouse I tried adxl345 work with other components and also standalone and component works fine also I check I2P adress and its 0x53 I have like this GND, 5V and SDA and SCL connected to SDA and SCL pins on arduino uno right above the digital 13 pin. I am using those becouse BMP280 is already on analog pins A4 and A5. This is the code I am trying to use that contains also ADXL345 but it gives Error opening data file!:
#include <SD.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h> // Include library for ADXL345 sensor
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345);
sensors_event_t event; // Declare event variable at a higher scope
File dataFile;
TinyGPSPlus gps;
  ss.begin(GPSBaud);
  if (!SD.begin(10))
    return;
    while (1);
  if (!accel.begin())
    Serial.println("Could not find a valid ADXL345 sensor, check wiring!");
    while (1);
  accel.getEvent(&event); // Read accelerometer data in the loop
      saveLocation();
  delay(100);
bool saveLocation()
  if (dataFile)
      dataFile.println("Latitude\tLongitude\tTemperature (C)\tPressure (hPa)\tAltitude (m)\tX\tY\tZ"); // Add X, Y, Z headers
    dataFile.print(bmp280.readAltitude(1013.25), 2);
    // Write X, Y, Z measurements to file
    dataFile.print(event.acceleration.x);
    dataFile.print(event.acceleration.y);
    dataFile.println(event.acceleration.z);
    dataFile.close();
    Serial.print("\t");
    Serial.print("\t");
    Serial.print("\t");
    Serial.print("\t");
    Serial.print(bmp280.readAltitude(1013.25), 2);
    Serial.print("\t");
    Serial.print(event.acceleration.x);
    Serial.print("\t");
    Serial.print(event.acceleration.y);
    Serial.print("\t");
    Serial.println(event.acceleration.z);
    return true;
    return false;
If anyone know what could cause this issue and could help me since I am not really good with coding I would really appreciate it.
have you tested the adxl345 alone?
Yes i did it works fine alone and also with some components. Its only issue when I am trying to write data to the file for some reason with all the components combined.
you are possibly hitting a memory issue on your UNO
do you get a warning at the end of the compilation process that memory is low?
first thing to do, use the F() macro to get the printed texts into flash memory ➜ change all the
    Serial.print("xxx");
    Serial.println("xxx");
    dataFile.print("xxx");
    dataFile.println("xxx");
into
    Serial.print(F("xxx"));
    Serial.println(F("xxx"));
    dataFile.print(F("xxx"));
    dataFile.println(F("xxx"));
when you print only 1 character like
use instead
    dataFile.write('\t');
and see how much RAM you saved and if it works better
So I think u might have helped me with this one and in fact it was the memory I am using this code now and it works very well but I had to remove decimals since macro F doesnt support 2 values. I got this error when I was trying to use decimal numbers
C:\Users\Samuel\AppData\Local\Temp\.arduinoIDE-unsaved2024215-6628-l5yvsk.gs327\sketch_mar15a\sketch_mar15a.ino:77:43: error: macro "F" passed 2 arguments, but takes just 1
     dataFile.print(F(gps.location.lat(), 6));
C:\Users\Samuel\AppData\Local\Temp\.arduinoIDE-unsaved2024215-6628-l5yvsk.gs327\sketch_mar15a\sketch_mar15a.ino:79:43: error: macro "F" passed 2 arguments, but takes just 1
     dataFile.print(F(gps.location.lng(), 6));
C:\Users\Samuel\AppData\Local\Temp\.arduinoIDE-unsaved2024215-6628-l5yvsk.gs327\sketch_mar15a\sketch_mar15a.ino:81:49: error: macro "F" passed 2 arguments, but takes just 1
     dataFile.print(F(bmp280.readTemperature(), 2));
C:\Users\Samuel\AppData\Local\Temp\.arduinoIDE-unsaved2024215-6628-l5yvsk.gs327\sketch_mar15a\sketch_mar15a.ino:83:54: error: macro "F" passed 2 arguments, but takes just 1
     dataFile.print(F(bmp280.readPressure() / 100.0, 2));
C:\Users\Samuel\AppData\Local\Temp\.arduinoIDE-unsaved2024215-6628-l5yvsk.gs327\sketch_mar15a\sketch_mar15a.ino:85:53: error: macro "F" passed 2 arguments, but takes just 1
     dataFile.print(F(bmp280.readAltitude(1013.25), 2));
C:\Users\Samuel\AppData\Local\Temp\.arduinoIDE-unsaved2024215-6628-l5yvsk.gs327\sketch_mar15a\sketch_mar15a.ino:97:41: error: macro "F" passed 2 arguments, but takes just 1
     Serial.print(F(gps.location.lat(), 6));
C:\Users\Samuel\AppData\Local\Temp\.arduinoIDE-unsaved2024215-6628-l5yvsk.gs327\sketch_mar15a\sketch_mar15a.ino:99:41: error: macro "F" passed 2 arguments, but takes just 1
     Serial.print(F(gps.location.lng(), 6));
C:\Users\Samuel\AppData\Local\Temp\.arduinoIDE-unsaved2024215-6628-l5yvsk.gs327\sketch_mar15a\sketch_mar15a.ino:101:47: error: macro "F" passed 2 arguments, but takes just 1
     Serial.print(F(bmp280.readTemperature(), 2));
C:\Users\Samuel\AppData\Local\Temp\.arduinoIDE-unsaved2024215-6628-l5yvsk.gs327\sketch_mar15a\sketch_mar15a.ino:103:52: error: macro "F" passed 2 arguments, but takes just 1
     Serial.print(F(bmp280.readPressure() / 100.0, 2));
exit status 1
Compilation error: macro "F" passed 2 arguments, but takes just 1
But after removing decimals from code it works fine now and it prints everything: Longittude, Lattitude, Alttitude, Pressure, X,Y,Z temperature. Can u help with this code and how could I add decimals different way since I cant use them with this method. Code:
#include <SD.h>
#include <Wire.h>
File dataFile;
TinyGPSPlus gps;
  ss.begin(GPSBaud);
  if (!SD.begin(10))
    Serial.println(F("SD Card initialization failed!"));
    return;
    Serial.println(F("Could not find a valid BMP280 sensor, check wiring!"));
    while (1);
  if (!accel.begin())
    Serial.println(F("Could not find a valid ADXL345 sensor, check wiring!"));
    while (1);
      saveLocation();
      Serial.println(F("Data has been written"));
  delay(100);
bool saveLocation()
  dataFile = SD.open(F("gps_data.txt"), FILE_WRITE);
  if (dataFile)
      dataFile.println(F("Latitude\tLongitude\tTemperature (C)\tPressure (hPa)\tAltitude (m)\tX\tY\tZ")); // Add X, Y, Z headers
    dataFile.print(gps.location.lat());
    dataFile.print('\t');
    dataFile.print(gps.location.lng());
    dataFile.print(bmp280.readTemperature());
    dataFile.print(bmp280.readPressure() / 100.0);
    dataFile.print(bmp280.readAltitude(1013.25));
    dataFile.close();
    Serial.print(gps.location.lat());
    Serial.print('\t');
    Serial.print(gps.location.lng());
    Serial.print('\t');
    Serial.print(bmp280.readTemperature());
    Serial.print('\t');
    Serial.print(bmp280.readPressure() / 100.0);
    Serial.print('\t');
    Serial.print(bmp280.readAltitude(1013.25));
    Serial.print('\t');
    Serial.print('\t');
    Serial.print('\t');
    return true;
    Serial.println(F("Error opening data file!"));
    return false;
The F() macro is only for text. keep the printing of the variable as it was
use F() only when you had text in between double quotes like print("Hello") becomes print(F("Hello") but print(variable) stays as print(variable)
Thank you very much I tried to find solution for 2 days u helped me in less then 1hr can I maybe reccomend u or reward u on this app with something ?
I see you kept
    Serial.print('\t');
no need to use print for just one char - use write ➜ change them into
    Serial.write('\t');
will do thanks.
it's also a good practice to have a "clean" end of a function that returns something to make it easy to read
for example, drop the else part in this. If all worked you enter in the if (datafile) and there is a return there.
bool saveLocation() {
  if (dataFile)  {
    dataFile.close();
    Serial.write('\t');
    Serial.write('\t');
    Serial.write('\t');
    Serial.write('\t');
    Serial.write('\t');
    Serial.write('\t');
    Serial.write('\t');
    return true;
  // <<< no else, just clean exit from the function without wondering what's going on
  return false;
I am kinda new to arduino and arduino ide so I still dont know all the tricks but I am trying my best and u helped a lot thank u again now I might pass my class with this. Thank u !!
have fun - don't ignore compiler's or IDE's warnings
