i need help with this code
hy all, im new with arduino nd i hve project to make home securiti, im use sensor PIR and keypad,
i try to find and rebuild or combine the source but thil hve trouble,
there is my code
#include <Password.h> //http://www.arduino.cc/playground/uploads/Code/Password.zip
#include <Keypad.h> //http://www.arduino.cc/playground/uploads/Code/Keypad.zip
enum {
  Alarm_on,
  alarm_of,
} state;
int ledpin = 12;
int spkrpin = 10;
int pirpin = 11;
int pirstate = LOW;
int val = 0;
int calibrationTime = 5;
long unsigned int lowIn;
long unsigned int pause = 5000;
Password password = Password( "1234" );
const byte ROWS = 4; // Four rows
const byte COLS = 4; //  columns
// Define the Keymap
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = { 9,8,7,6 };// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte colPins[COLS] = { 5,4,3,2, };// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
 pinMode(ledpin, OUTPUT);// set up serial port
 pinMode(spkrpin,OUTPUT);
 pinMode(pirpin,INPUT);
 digitalWrite(ledpin, LOW);
 digitalWrite(pirpin,HIGH);
   Serial.print("calibrating sensor ");
    for(int i = 0; i < calibrationTime; i++){
      Serial.print(".");
    Serial.println(" done");
    Serial.println("SENSOR ACTIVE");
    delay(50);
  keypad.addEventListener(keypadEvent); //add an event listener for this keypad
void loop(){
  keypad.getKey();
//take care of some special events
void keypadEvent(KeypadEvent eKey){
  switch (keypad.getState()){
    case PRESSED:
	Serial.print("Pressed: ");
	Serial.println(eKey);
	switch (eKey){
	  case '*': checkPassword(); break;
	  case '#': password.reset(); break;
	  default: password.append(eKey);
void checkPassword(){
  if (password.evaluate()){
    Serial.println("Success");
    state=Alarm_on;
    //Add code to run if it works
  }else{
    Serial.println("Wrong");
    //add code to run if it did not work
switch (state){
  case Alarm_on: {
    val = digitalRead(pirpin);
    if ( val == HIGH) {
      delay(150);
      if (pirstate == LOW){
        digitalWrite(ledpin, HIGH);
        digitalWrite(spkrpin, HIGH);
        Serial.println("movement");
        pirstate = HIGH;
    else {
      if (pirstate == HIGH){
        digitalWrite(spkrpin, LOW);
        Serial.println("AMAN");
  case alarm_of :{
    digitalWrite(ledpin,LOW);
      digitalWrite(spkrpin,LOW);
ty before :d
What trouble do you have ?
Does the code compile or do you get errors ?
What should the code do and what does it actually do ?
UKHeliBob:
no error with compile,
but after i test, this program not work,
password success but pir sensor always detect motions even no one near it
That line looks wrong to me.
I don't think so - the compiler allows hanging commas.
Does the PIR really always detect motion (in which case, you don't have a programming problem), or does the pin it is connected to appear to always trigger?
Do you have a schematic?
It may allow it, but it still looks wrong.
It's a useful feature when used in conjunction with the preprocessor - you can create simple macros to generate tables without caring about the last entry.
AWOL:
thank for respon sir and all
but can u give me a example, i really new with this arduino
UKHeliBob:
i think no mistake with keypad code, i just trouble with sensor(pir) code,
i really dont know hoe to combine PIR and keypad :frowning:
If there's no problem with the keypad code, write a simple sketch to help you figure out why you think the PIR is always triggering.
Maybe it is, or maybe you just have a floating input.
Don't you need to set pirstate back to LOW in this piece of code? Otherwise it will print "AMAN" repeatedly while the PIR input remains low.
By the way, I would hardly describe what you're doing in setup() as "calibrating sensor"! :slight_smile:
PeterH:
By the way, I would hardly describe what you're doing in setup() as "calibrating sensor"! :)
i will try, thanks bro,
hahhaa calibrate sensor just for accesoris, not really calibrate, hehehhe
thank all
my project was fixed
:smiley:
