CrossRoads:
Do you notice the chips feeling any warmer when overclocked?
How much of the functionality of the chip have you tried at the higher speeds?
No heat whatsoever.
I work on many projects at once in my lab, and often leave the overclocked video generators running for months. The ATTiny-85 has been going at 40MHz since November, and the XMega running at 65MHz... I can't remember the last time I turned off the power to that side of my bench!
There is no spectacular flash-bang when you reach the limit. Usually what happens is the AVR begins to reset at a high rate. Sometimes it will even work at some harmonic. The 328 actually runs stable on a 60MHz clock oscillator, but only at 20Mhz.
I have not done a lot with over-volting yet though.
XMega does fine at 5v, but this does not improve the top overclocking speed.
I have heard that ATMega will do better between 5.5v and 6.0v, and I may test this soon.
Already getting 36MHz out of 'em, so I am happy with the results.
ATMega-644 and 1284 are the worst, with 25 Mhz being the "safe" top end.
Those 2 start to drop out at around 28 MHz.
Does the Arduino use a real clock or an Xtal?
I have never seen one, but know the Uno has a 328, which is why I chimed in here.
If it only has an Xtal, you would have to feed a real clock into Pin B.6.
Digikey has every possible frequency available, and you can order pre-programmed cans for a few bucks.
Here is a thread I started on AVRFreaks that will detail my 36MHz adventures with the ATMega-328...
http://www.avrfreaks.net/forum/quark-328-single-chip-184x160-vga-game-system-atmega-328
Again Mike, before you start shaking your cane... I am just having fun, so chill dude!
Brad
