Howdy
I am using the Arduino IDE . I want return the cursor to home postion with a line feed. The attached screen shots shows the Serial.print code. I am using the IDE screen monitor to display/enter data.
As you can see I'm using the "\r" char to home,expect it does not work. The data just appends to the last string.
So the question is what I am doing wrong?
Rocket Nut
Nothing wrong. Serial monitor isn't that advanced. I guess you can use any terminal program you want that can handle control codes.
guix
September 19, 2016, 7:29pm
3
Welcome,
Use another Serial monitor, such as RealTerm. It's not pretty, but much more powerful and will display as you want
DrAzzy
September 19, 2016, 7:32pm
4
Is the serial monitor set to break on carriage return? I think by default it breaks on CRLF not just CR, but there's a dropdown menu for that.
Why not just do Serial.println(); instead of Serial.print("\r"); ?
system
September 19, 2016, 7:35pm
5
Posting the same question twice within ten minutes.
(don't look for the other one, I deleted it)
AWOL:
Yes my bad. Just chalk it up to a newbe learning how things work.
