I'm trying to display output to the terminal without each line of output showing up on a new line. I'd like the output to remain in the same position in the window.
I can only see a few ASCII characters listed in this chart for terminal control. I don't see any characters to home the cursor.
I've tried ASCII characters 0 through 16. None of those seems to do much except for line feed, carriage return and tab. I didn't even get a bell with ASCII 7.
I thought I ran some Arduino code which the output to a single line. Was I imagining this? If not how do I move the cursor to the home position?
If you're talking about the serial monitor in the IDE, it doesn't do control characters. It is pretty basic. There are a number of other terminal applications which are far more functional. I like putty and realterm personally, but there are dozens to choose from.
Delta_G:
Yes, I'm referring to the serial monitor in the IDE. I must be remembering incorrectly because I thought I had used a program with kept the output in the same location in the window.
It seems like lots of people like putty. I'll give it a try.
The below uses Serial.print instead of Serial.println which keeps the returned data on the same line in the serial monitor.
//zoomkat 6-29-14 Simple serial echo test
//type or paste text in serial monitor and send
String readString;
Serial.println("Simple serial echo test"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the String readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.print(readString);
//Serial.println(readString); //so you can see the captured String
readString="";
zoomkat:
Yes, the data stays on the same line but it keeps extending to the right with each new entry. I'd like to have the output from a program remain on a single line with the new data replacing the old.
