I try hardest to answer a post when
When all the OP says is;
"My Arduino does not work anymore, how do I fix it ?"
  • It was working fine yesterday, promise I did not change anything and it no longer works. What could be wrong?
  • here is an image of my setup, and I2C and SPI do not work as I want… Ha, BTW, no i did not bother soldering the pins because I did not think that was so important.
can you give me code for....
Or its very near cousin "what is the code for < x, y, z >..?"
Or the impolite way « someone give me code asap for xxx »
From a few days back.
I want to do something that is impossible (actually says control 8 LEDs individually with 1 pin). Then he rejects using addressable LEDs and any external hardware and wants to do it all in software.
Is told no by several people and gets quite cross about it.
Finally marks up a solution to use 4 pins and charliplex them.
"Please explain to me how electronics work."
Existing knowledge base: knows how to plug phone charger into wall outlet.
"Here is a snippet of my code, the problem is definitely here so you don't need to see the rest".
"I have to use this part" coupled with "no it is not an assignment it is for my own study"
a non sarcastic answer: when you find out a bit of information that has always been left out. looked up install CP210X drivers. discovered that the CP210X driver creates a /dev/ttyUSB0 port, and that is the correct port to use to connect an ESP32. gee, you would think that would be a thing to put into a "How to use the Arduino IDE with ESP32" post.
Thank you @red_car for the bit of help in blowing off a bit of Arduino Forum Steam.
When a first time poster posts their code in code tags, includes a well done schematic, links to data sheets, clear photos of the project, description of requirements of the project and clear description of the issue(s) I will always try my best to help them.
That has never happened that I could see, but would help the poster if it did.
My teacher sucks, I need code
This is my final in robotics engineering, but I can't get this LED to turn on
anything by indrajithgamage
I am designing a drone, what batteries and motors should I use ?
Lead-acid, and a V8 flathead
d.) Where can I buy hydraulic legs for a bipedal android I am designing?
Sealed gel type I presume, for when the drone flies inverted ?
OPs who post in an (obviously) English forum in a non-English language.
My degree of frustration with ops is shown in my emojis, the java coefficient, it is an open ended scale.
:smiley: :+1: :coffee: :australia: excellent
:smiley: :coffee: :coffee: :australia: what, read my post ????
:smiley: :coffee: :coffee: :coffee: :australia: you have to be kidding!!!!!!
:smiley: :coffee: :coffee: :coffee: :coffee: :australia: that much caffiene can be leathal.... fritzy overload.
Tom... :smiley: :+1: :coffee: :australia:
