I use ldr to move my servo to 90 degrees when its reach my setpoint of darkness then after that i want it to go back to its initial position
#include <Servo.h>
Servo myservo;
int photocellPin = 0;
int photocellReading;
myservo.attach(3);
Serial.print("Brightness = ");
Serial.println(photocellReading);
photocellReading = analogRead(photocellPin);
photocellReading = map(photocellReading, 0, 1023, 0, 179);
if
(photocellReading <= 89); //if the LDR is showing less than half light intensity
myservo.write(90);
delay(100);
Hello iyanitski and welcome to the worldbest Arduino Forum
something like this maybe?
(compiles, NOT tested!)
#include <Servo.h>
Servo myservo;
bool servo_moved = false;
  myservo.attach(3);
  if (servo_moved = false) {
    if (photocellReading <= 89) { //if the LDR is showing less than half light intensity
      myservo.write(90); //move to 90 deg position
      servo_moved = true;
  else {
    if (photocellReading > 89) { //if the LDR is showing more than half light intensity
      myservo.write(0); //move to 0deg position
  delay(100);
hope that helps....
Please check the syntax of "if" statement. Your condition do nothing because the superficial ';' in the end of line.
@sherzaad
Please do not do for OP his homework :slight_smile:
thanks bro but what i mean is, the return to 0 is not dependent when the ldr showing more than half of light. what i want is when the ldr showing less than half of light the servo turns to 90 then automatically back to 0. in every reading that shows less than of light the servo turns to 90 then automatically back to 0. can you help me plsss
so if I understood you want the servo to move 0->90->0 when the target LDR level is detected.
if you are using a servo without feedback then probably the easiest way is to use a 'tuned' delay ie:
delay(x); //x milliseconds delay
myservo.write(0); //return to 0 deg position
if you are using a servo with feedback like this one then the other way of doing it is to keep reading the feedback (analogRead) within 'loop' and one it reach the 90deg position, run the "myservo.write(0); " to return the servo to zero position.
hope that helps....
how can i put that in a program?
