I want to add hourly beep sound on 7 segment led clock
I want to add a buzzer that beep in every hour with number of hour, I have tried to add this on my existing 7 segment led clock but failed. can anyone help me?
the code is here:
 4 digit 7 segment display: http://www.sparkfun.com/products/9483
 Datasheet: http://www.sparkfun.com/datasheets/Components/LED/7-Segment/YSD-439AR6B-35.pdf
// modified connexion by niq_ro from http://nicuflorica.blogspot.com
// dataseet: http://www.tme.eu/ro/Document/dfc2efde2e22005fd28615e298ea2655/KW4-563XSA.pdf
// Code modified by BMIAK Basnayaka
// http://www.setnfix.com
int digit1 = 12;
int digit2 = 11;
int digit3 = 10;
int digit4 = 9;
//Pin mapping from Arduino to the ATmega DIP28 if you need it
//http://www.arduino.cc/en/Hacking/PinMapping
int segA = 0; //Display pin 0
int segB = 1; //Display pin 1
int segC = 2; //Display pin 2
int segD = 3; //Display pin 3
int segE = 4; //Display pin 4
int segF = 5; //Display pin 5
int segG = 6; //Display pin 6
int segDP =13; // Display pin 13
int rtc[7];
bool buzzerPlaying = 0;
const int buzzer = 7;
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
// original sketck from http://learn.adafruit.com/ds1307-real-time-clock-breakout-board-kit/
// add part with SQW=1Hz from http://tronixstuff.wordpress.com/2010/10/20/tutorial-arduino-and-the-i2c-bus/
// add part with manual adjust http://www.bristolwatch.com/arduino/arduino_ds1307.htm
byte SW0 = A0;
byte SW1 = A2;
byte SW2 = A1;
byte SWT = A3;
int Adhr=0;
int Admnt=0;
int D = 0;
int Z =0;
// use for hexa in zecimal conversion
long zh, uh, ore;
long zm, um, miniti;
 //Serial.begin(57600);
  Wire.begin();
  RTC.begin();
 // RTC.adjust(DateTime(F(__DATE__), F(__TIME__)));
// if you need set clock... just remove // from line above this
// part code for flashing LED
Wire.beginTransmission(0x68);
Wire.write(0x07); // move pointer to SQW address
// Wire.write(0x00); // turns the SQW pin off
 Wire.write(0x10); // sends 0x10 (hex) 00010000 (binary) to control register - turns on square wave at 1Hz
// Wire.write(0x13); // sends 0x13 (hex) 00010011 (binary) 32kHz
Wire.endTransmission();
  pinMode(segA, OUTPUT);
  pinMode(segB, OUTPUT);
  pinMode(segC, OUTPUT);
  pinMode(segD, OUTPUT);
  pinMode(segE, OUTPUT);
  pinMode(segF, OUTPUT);
  pinMode(segG, OUTPUT);
  pinMode(segDP, OUTPUT);
  pinMode(digit1, OUTPUT);
  pinMode(digit2, OUTPUT);
  pinMode(digit3, OUTPUT);
  pinMode(digit4, OUTPUT);
//Serial.begin(9600);
pinMode(SW0, INPUT);  // N.O. push button switch
pinMode(SW1, INPUT);  // N.O. push button switch
pinMode(SW2, INPUT);  // N.O. push button switch
pinMode(SWT, INPUT);  // N.O. push button switch
digitalWrite(SW0, HIGH); // pull-ups on
digitalWrite(SW1, HIGH);
digitalWrite(SW2, HIGH);
digitalWrite(segDP, LOW);
  DateTime now = RTC.now();
  long HR = now.hour()*1000;
  long timp = (HR*10)+now.minute()*100+now.second();
  Adhr = now.hour();
  Admnt=now.minute();
int DIM = 0;
if (timp >=250000)
timp=timp-240000;
//12/24 hours shitching
if (timp < 130000){
digitalWrite(segDP, LOW);}
if (digitalRead(SWT)==0){delay(300);
 if (D == 0) {
 D =1;delay(200);}
else{
D =0;}
if (D == 0){
if (timp>=130000){
timp=timp-120000;
digitalWrite(segDP, HIGH);}
if (timp>=130000){
if ((D==1)& (timp <130000))
//int timp = (now.minute(), DEC);
//   displayNumber(12); // this is number to diplay
    for(int i = 100 ; i >0  ; i--) {
     if (timp >= 100000) displayNumber01(timp);
     else displayNumber02(timp);
     if (timp >= 100000) displayNumber03(timp);
     else displayNumber04(timp);
     if (timp >= 100000) displayNumber05(timp);
     else displayNumber06(timp);
if (digitalRead(SW0)==0){delay(100);Z=1;  set_time(); }// hold the switch to set time
void set_time()   {
  byte minutes1 = 0;
  byte hours1 = 0;
  byte minutes = 0;
  byte hours = 0;
  hours=Adhr;
  minutes=Admnt;
    if ((hours & 0x0f) > 9) hours =  hours + 6;
      if (hours > 0x24) hours = 1; // Mid night 12.00 will show as 12:00 (With PM LED on) or 24:00
        //if (hours > 0x24) hours = 1; // Mid night 12.00 will show as 0:00
        if ((minutes & 0x0f) > 9) minutes = minutes + 6;
      if (minutes > 0x59) minutes = 0;
while (!(Z==0)){ // set time switch must be released to exit
   int TST = digitalRead(SW2);
    while (TST==0) // set hours
     hours++;
   // converting hexa in zecimal:
    zh = hours / 16;
    uh = hours - 16 * zh ;
    ore = 10 * zh + uh;
    zm = minutes / 16;
    um = minutes - 16 * zm ;
    miniti = 10 * zm + um;
        if (hours <= 9)
    delay(1);
      for(int i = 400 ; i >0  ; i--) {
     displayNumber01(ore*10000+miniti*100);
   while (!(digitalRead(SW1))) // set minutes
     minutes++;
    zh = hours / 16;
    ore = 10 * zh + uh;
    zm = minutes / 16;
      if (minutes >= 9)
    delay(1);
    Wire.beginTransmission(0x68); // activate DS1307
    Wire.write(0); // where to begin
    Wire.write(0x00);          //seconds
    Wire.write(minutes);          //minutes
    Wire.write(0x80 | hours);    //hours (24hr time)
    Wire.write(0x06);  // Day 01-07
    Wire.write(0x01);  // Date 0-31
    Wire.write(0x05);  // month 0-12
    Wire.write(0x09);  // Year 00-99
    Wire.write(0x10); // Control 0x10 produces a 1 HZ square wave on pin 7.
    zh = hours / 16;
    ore = 10 * zh + uh;
    zm = minutes / 16;
delay(100);
//Serial.print(digitalRead(SW0));
if (digitalRead(SW0)==0) Z = 0;
 delay(300);
//Serial.print(SW2);
void displayNumber01(long toDisplay) {
#define DISPLAY_BRIGHTNESS  25
#define DIGIT_ON  HIGH
#define DIGIT_OFF  LOW
  for(int digit = 6 ; digit > 0 ; digit--) {
    //Turn on a digit for a short amount of time
    switch(digit) {
    case 1:
     digitalWrite(digit1, DIGIT_ON);
   case 2:
      digitalWrite(digit2, DIGIT_ON);
      //digitalWrite(segDP, LOW);
    case 3:
      digitalWrite(digit3, DIGIT_ON);
    case 4:
      digitalWrite(digit4, DIGIT_ON);
    lightNumber(toDisplay % 10);
    toDisplay /= 10;
    delayMicroseconds(DISPLAY_BRIGHTNESS);
     //Turn off all segments
    lightNumber(10);
    //Turn off all digits
    digitalWrite(digit1, DIGIT_OFF);
    digitalWrite(digit2, DIGIT_OFF);
    digitalWrite(digit3, DIGIT_OFF);
    digitalWrite(digit4, DIGIT_OFF);
void displayNumber02(long toDisplay) {
    switch(digit) {
    case 1:
     lightNumber(10);
   case 2:
    case 3:
    case 4:
    toDisplay /= 10;
    lightNumber(10);
void displayNumber03(long toDisplay) {
    switch(digit) {
    case 1:
   case 2:
    case 3:
    case 4:
    toDisplay /= 10;
    lightNumber(10);
void displayNumber04(long toDisplay) {
    switch(digit) {
    case 1:
     lightNumber(10);
   case 2:
    case 3:
    case 4:
    toDisplay /= 10;
    lightNumber(10);
void displayNumber05(long toDisplay) {
    switch(digit) {
    case 1:
   case 2:
    case 3:
    case 4:
    toDisplay /= 10;
    lightNumber(10);
void displayNumber06(long toDisplay) {
    switch(digit) {
    case 1:
     //digitalWrite(digit1, DIGIT_ON);
   case 2:
    case 3:
    case 4:
    toDisplay /= 10;
    lightNumber(10);
//Given a number, turns on those segments
//If number == 10, then turn off number
void lightNumber(int numberToDisplay) {
//Common Anode *************************
#define SEGMENT_ON  HIGH
#define SEGMENT_OFF LOW
  switch (numberToDisplay){
  case 0:
    digitalWrite(segA, SEGMENT_ON);
    digitalWrite(segB, SEGMENT_ON);
    digitalWrite(segC, SEGMENT_ON);
    digitalWrite(segD, SEGMENT_ON);
    digitalWrite(segE, SEGMENT_ON);
    digitalWrite(segF, SEGMENT_ON);
    digitalWrite(segG, SEGMENT_OFF);
  case 1:
    digitalWrite(segA, SEGMENT_OFF);
    digitalWrite(segD, SEGMENT_OFF);
    digitalWrite(segE, SEGMENT_OFF);
    digitalWrite(segF, SEGMENT_OFF);
  case 2:
    digitalWrite(segC, SEGMENT_OFF);
    digitalWrite(segG, SEGMENT_ON);
  case 3:
  case 4:
  case 5:
    digitalWrite(segB, SEGMENT_OFF);
  case 6:
  case 7:
  case 8:
  case 9:
  // all segment are ON
  case 10:
// End of the coding, BUDHUSARANAI, Best of luck.
/*void playHourBuzzer() {
    if((rtc[0] >= 2 && rtc[0] < 30 ) && rtc[1] == 0 && buzzerPlaying == 0 && rtc[2] >= 7 && rtc[2] <= 21) { // if 00 min and seconds
      buzzerPlaying = 1 ;
      playBuzzer(rtc[2]);
      buzzerPlaying = 0 ;
      return;
    else {
      buzzerPlaying = 0 ;
void playBuzzer( int numberofTimes ){
  for(int b = 1; b <= numberofTimes; b ++ ) {
    analogWrite(buzzer, 20);
    delay(500);        // ...for 1 sec
    analogWrite(buzzer, 0);
    return;
What Arduino? PIn 7 isn't a PWM pin on many of them.
"Failed" is not a very useful description of a problem. What if anything happens?
What type of buzzer? Why use analogWrite()? Passive buzzers normally use the tone() command and active buzzers normally use digitalWrite(). Does your buzzer make any sound with a simple program that just drives it?
Steve
    return;
Apart from any other problems in the sketch (I didn't look too closely) this for loop will not work because you return from the function from within it so the for loop never actually loops
active buzzer used in my project, I have tried with pin no 6 but there is no result, code compile successfully and uploaded but the buzzer not working....i have use arduino pin output to buzzer positive leg and GND to GND.
remember when you have last beeped and beep again, if the hour changes.
add this function and call it in loop
The function will check if it is time to beep.
Proposal, untested:
void timerBeep()
  int currentHour = now.hour();
  static int lastBeep = 0;
  if (lastBeep != currentHour)
    lastBeep = currentHour;
    playBuzzer(2);
(does not fix your problem with playBuzzer, but you got already the hint ...)
In the only code I can see you're analogWrite() with a very small value (20 out of 255) to a pin that isn't a PWM pin. I can't comment on code I can't see.
Steve
