I have never interfaced LVDT and RTD with arduino uno and i am not getting where to start , can you tell me simple starting interfacing circuits which i can try on proteus software and then implement on hardware
A Google search for "Arduino RTD" will turn up dozens of tutorials. As will a search of this site. The LVDT will be more difficult as the output is, usually, AC and will need external components to make It work with Arduino. Again a Google search for "Arduino LVDT" turns up lots of information.
In a word, no. LVDT's and RTD's have fairly complex interface requirements, so unless Proteus has LVDT and RTD amplifier IC's it would be fairly complex to duplicate the functionality using op-amps, unless you are knowledgeable in electronic design. I've never used Proteus.
That said, why do you need that level of detail in your Proteus simulation? If you get RTD and LVDT interface IC's the outputs are going to be simple analog or serial signals.
Welcome to the forum.
Can you post links to your RTD and LDVT, so we can see what sort of output your devices have,
What model Arduino are you using?
Thanks.... Tom.
