int greenLed = 9; // set pin 9 to a variable
int yellowLed = 10; // set pin 10 to a variable
int redLed = 11; // set pin 11 to a variable
int buttonA = 4; // set pin 4 to a variable
int buttonB = 2; // set pin 2 to a variable
int potPin = A0; // set pin A0 to a variable
int potSensorValue = 0; // ADC Read Value
int ledLevel = 255; // LED Brightnes
void setup ()
pinMode (greenLed, OUTPUT); // set Green LED pin to output
pinMode (yellowLed, OUTPUT); // set yellow LED pin to output
pinMode (redLed, OUTPUT); // set red LED pin to output
pinMode (buttonA, INPUT_PULLUP); // set buttoA to pullup input
pinMode (buttonB, INPUT_PULLUP); // set buttonB to pullup input
pinMode (potPin, INPUT); // set A0 to input
potSensorValue = analogRead(potPin);
ledLevel = map(potSensorValue, 0, 0123, 0, 255);
analogWrite(greenLed, ledLevel); // Turn on Green LED Dim setting
delay(1000); // wait for 1000 millisecond(s)
analogWrite(yellowLed, ledLevel); // Turn on Yellow LED Full brightnes setting
analogWrite(redLed, ledLevel); // Turn on Red LED Med setting
digitalWrite(greenLed, LOW); // Turn off Green LED
digitalWrite(yellowLed, LOW); // Turn off Yellow LED
digitalWrite(redLed, LOW); // Turn off Red LED
Use map just like you did there to map the pot reading to your min and max intervals (except you probably meant 1023 not 0123).
To make it NOT control the LED level, change this line to:
ledLevel = 255;
(Or whatever fixed value your want for your level.)
