I2c adresse problem mlx90614 on wio terminal
#include <Adafruit_MLX90614.h>
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
  while (!Serial);
  Serial.println("Adafruit MLX90614 test");
  if (!mlx.begin()) {
    Serial.println("Error connecting to MLX sensor. Check wiring.");
    while (1);
  Serial.print("Emissivity = "); Serial.println(mlx.readEmissivity());
  Serial.println("================================================");
  Serial.print("Ambient = "); Serial.print(mlx.readAmbientTempC());
  Serial.print("*C\tObject = "); Serial.print(mlx.readObjectTempC()); Serial.println("*C");
  Serial.print("Ambient = "); Serial.print(mlx.readAmbientTempF());
  Serial.print("*F\tObject = "); Serial.print(mlx.readObjectTempF()); Serial.println("*F");
I would like to operate an IR temperature sensor MLX90614 with Wio terminal - this sensor uses the I2C interface. I used pins 3 and 5 or 25 and 26 for SCL and SDA, but without result.
While it works very well with an arduino nano ble sense.
I use the "Adafruit_MLX90614" library. I tried to use an I2C scan program to get the sensor address.
I was able to get the address i2c but it didn't work
but if I use another i2c sensor it works perfectly with the wio terminal.
According to the pinout of your board (for such exotic boards you should definitely provide a link to the hardware documentation!) I2C0 is on 27 and 28.
Thank you for your reply
that's right, I2C0 is on 27 and 28
Does it work on these pins?
No, it's the same
Post a wiring diagram and links to all components including breakout boards you might use (so if the MLX90614 is on a board we need a link to the schematics of that board).
