hi i m try to use my oled screen with my gps . but it stuck in "display.begin(...)" line.
my display code work fine with separetely. but when i paste in gps code it dont go further.
i place two "Serial.println()" line. i can see first one in my computer. but it stuck there and dont write the other print line. maybe libraries dont work together? how can i solve this problem?
relevent part
ss.begin(GPSBaud);
//oled
Serial.println("This line writes serial monitor perfectly");
display.begin(i2c_Address, true); // Address 0x3C default
Serial.println("Error Here- this is not displayed. only above code. and didnt go furter than this-stuck here");
display.clearDisplay();
my all code
modified on Sep 27, 2020
Modified by MohammedDamirchi from https://github.com/mikalhart/TinyGPSPlus
Home
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
This sample sketch demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
It requires the use of SoftwareSerial, and assumes that you have a
9600-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
//timer
unsigned long previousMillis = 0;
unsigned long currentMillis = 0;
//distance calculation
float start_lat, start_lon, flat, flon;
unsigned long age, date, time, chars = 0;
unsigned short sentences = 0, failed = 0;
double s_latitude=39 ;
double s_longitude=27 ;
double f_latitude ;
double f_longitude ;
unsigned long sum_distance1=0;
unsigned long sum_distance2=0;
#include <math.h>
//oled
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
/* Uncomment the initialize the I2C address , uncomment only one, If you get a totally blank screen try the other*/
#define i2c_Address 0x3c //initialize with the I2C addr 0x3C Typically eBay OLED's
//#define i2c_Address 0x3d //initialize with the I2C addr 0x3D Typically Adafruit OLED's
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // QT-PY / XIAO
Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
ss.begin(GPSBaud);
//oled
Serial.println("Start oled");
Serial.println("Error Here");
display.setTextSize(1);
display.setTextColor(SH110X_WHITE);
display.setCursor(0, 0);
display.println("Mesafe Olcer");
display.setCursor(0, 20);
display.println("v2");
display.display();
delay(2000);
double haversine(double lat1, double lon1, double lat2, double lon2) {
const double rEarth = 6371000.0; // in meters
double x = pow( sin( ((lat2 - lat1)*M_PI/180.0) / 2.0), 2.0 );
double y = cos(lat1*M_PI/180.0) * cos(lat2*M_PI/180.0);
double z = pow( sin( ((lon2 - lon1)*M_PI/180.0) / 2.0), 2.0 );
double a = x + y * z;
double c = 2.0 * atan2(sqrt(a), sqrt(1.0-a));
double d = rEarth * c;
// Serial.printlnf("%12.9f, %12.9f, %12.9f, %12.9f, %12.9f, %12.9f", x, y, z, a, c, d);
return d; // in meters
void displayInfo(){
Serial.println("----------------------");
f_latitude = gps.location.lat();
f_longitude = gps.location.lng();
unsigned long distance=
(unsigned long)TinyGPSPlus::distanceBetween(
f_latitude,
f_longitude,
s_latitude,
s_longitude);
if (distance<200 && distance>0) sum_distance1+=distance;
// unsigned long distance2=
// (unsigned long)TinyGPSPlus::distanceBetween(
// 39,
// 27,
// 39.001,
// 27.002) ;
//unsigned long distance3=haversine(39,27,39.001,27.002);
Serial.print("s_latitude");Serial.println(s_latitude,6);
Serial.print("s_longitude");Serial.println(s_longitude,6);
Serial.print("f_latitude");Serial.println(f_latitude,6);
Serial.print("f_longitude");Serial.println(f_longitude,6);
Serial.print("distance :");Serial.println(distance,9);
// Serial.print("distance2 :");Serial.println(distance2,9);
// Serial.print("distance3 :");Serial.println(distance3,9);
Serial.print("sum_distance1 :");Serial.println(sum_distance1,9);
s_latitude = f_latitude ;
s_longitude = f_longitude;
Serial.print(F("Location: "));
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6 );
Serial.print(F(","));
Serial.print(gps.location.lng(), 6);
Serial.print(F("INVALID"));
Serial.print(F(" Date/Time: "));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F("/"));
Serial.print(gps.date.day());
Serial.print(gps.date.year());
Serial.print(F(" "));
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F("0"));
Serial.print(gps.time.hour());
Serial.print(F(":"));
if (gps.time.minute() < 10) Serial.print(F("0"));
Serial.print(gps.time.minute());
if (gps.time.second() < 10) Serial.print(F("0"));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F("0"));
Serial.print(gps.time.centisecond());
void loop(){
// collect data every 3 sec
while (ss.available() > 0){
currentMillis=millis();
if (gps.encode(ss.read()) && ( currentMillis - previousMillis >= 3000 ) ){
displayInfo();
previousMillis=millis();
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
while(true);
edit: i am using arduino uno board.
edit2: now i awere that it is definatlly software serial problem. because whenever i write;
my board is stuck. do u have any recomendation
