Hey guys,
I am a complete beginner when it comes to i2c and the Arduino Due, so sorry if this is a dumb question. I am trying to set up i2c communication to a load cell (Datasheet: https://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Data+SheetFX29A5pdfEnglishENG_DS_FX29_A5.pdfCAT-FSE0006). When I originally wrote the code for the arduino uno and esp32 and it works for those boards. My code is shown below:
#include <Wire.h>
#define UseDebug 1
#define clockFrequency 400000
#define zeroOffset 970
#define linearity 130.2
int curAddress = 0x28;
Wire.begin(); //Starts I2C, will need to change these two values (or delete them)
Wire.setClock(clockFrequency); //Sets I2C frequency to fastest
Wire.beginTransmission(curAddress); //Request Measurement
Wire.endTransmission();
delay(100); //Delay for measurement to be taken (could be done in IRQ)
Wire.requestFrom(curAddress, 2); //Requests two bytes of data
byte msb = Wire.read();
byte lsb = Wire.read();
#if (UseDebug)
byte statusVals = msb/64; //Determines the status values from the measurement to ensure a new measurement was taken
Serial.print("status:");
Serial.println(statusVals, BIN);
Serial.print("msb:");
Serial.println(msb, BIN);
Serial.print("lsb:");
Serial.println(lsb, BIN);
#endif
int dataVal = (msb%64)*256 + lsb; //Throws out the status bits and converts the measurement data into a single int
Serial.print("dataValue:");
Serial.println(dataVal);
float weightVal = (dataVal-zeroOffset)/linearity; //Adjusts the data with the above linearity and zero-offset vals
Serial.println("Weight: " + String(weightVal) + " lbs");
When using my uno or esp I get the following output with no load applied:
Status: 0
msb: 11
lsb: 11110011
dataValue: 1011
Weight: 0.31 lbs
While I get this for the due:
Status: 0
msb: 11111
lsb: 10101011
dataValue: 8107
Weight: 54.82 lbs
Thanks for any help and let me know if you need more information.
