Trying to communicate Arduino Mega 2560 on I2C to a 16x12 bit PWM Shield which further connects to a PWM to 0-10V converter. Unfortunately, the communication fails to establish.
Which pins on the Mega is the 16x12 connected to? Just in case, A4 and A5 are not the I2C pins.
A schematic would have been (and more than likely still is) useful; photo of pencil/paper drawing is fine.
How do you know this?
Does the I2C scan sketch find the devices?
Scan sketch? Could you elaborate this for me? I did not find any indication on shield device for I2C and didn't get any output at the end (LED end) so I concluded that somewhere I'm failing at I2C end itself.
Jim-p means the i2c_scanner sketch.
In the Arduino, click on File then Examples, then Wire, then I2C_scanner.
Upload the program. It should report that is found something at some address.
