PCA9685 AND Arduino micro i2c communication
Hello. I have lately been quite frustrated with an issue i have been having.
The main problem is:
I2C Scanner
Scanning...
No I2C devices found
I have connected pca9685 to arduino micro. A5 to scl A4 to sda 5v to vcc.
the code i used to test i2c communication
// i2c_scanner
// Version 1
//    This program (or code that looks like it)
//    can be found in many places.
//    For example on the Arduino.cc forum.
//    The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
//     Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26  2013
//    V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
//    by Arduino.cc user Krodal.
//    Changes by louarnold removed.
//    Scanning addresses changed from 0...127 to 1...119,
//    according to the i2c scanner by Nick Gammon
//    http://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
//    As version 4, but address scans now to 127.
//    A sensor seems to use address 120.
// Version 6, November 27, 2015.
//    Added waiting for the Leonardo serial communication.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
  Wire.begin();
  while (!Serial);             // Leonardo: wait for serial monitor
  Serial.println("\nI2C Scanner");
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknown error at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.println(address,HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
    Serial.println("done\n");
  delay(5000);           // wait 5 seconds for next scan
also i want to add that i tested on another pca9685 board. the same problem...
the issue i originatly had with servos not moving. then i discovered this problem.
Welcome.
Did you forget to describe a connection in that?
oh and gnd to gnd sorry.
the 5v to v+ is not important as i wont use it i for got unplug it.
I think on the Micro SCL and SDA aren't on A5/A4.
Looks like D2/D3. Try that.
Beyond that, those who use Micros might be able to better help you.
yep thank you. holy s**t man.. thanks
Good.
If this is resolved, click the 'solution' tickbox in your message window. That flags the topic so others won't have to read through to realize it's done with.
