I2C communication issues
Hi all,
I'm trying to setup I2C communication between 2 Arduino's, but I'm having some difficulties.
The code for Arduino A (Arduino A listens now for incoming I2C messages) looks like this:
#include <Wire.h>
// Define I2C addresses
#define LocalAddress 0x8
#define RemoteAddress 0x9
// Define I2C variables
#define BUF_LEN   128
#define TERM_CHAR '\n'
int i;
byte incomingChar;
char buf[BUF_LEN];
// Define Serial variables
#define SERIAL_BUFFER_SIZE        25
#define SERIAL_DELIMITER ','
char SerialBuffer[SERIAL_BUFFER_SIZE];
char  strValue[SERIAL_BUFFER_SIZE + 1]; // add one for the terminating null
  Wire.begin(LocalAddress);
  Wire.onReceive(receiveEvent);
void receiveEvent(int howMany){
  //clean buffer
  memset(buf,'\0',BUF_LEN); i = 0;
  // read incoming message
  while(Wire.available()){
   incomingChar = Wire.receive();
   if(incomingChar != TERM_CHAR && i != BUF_LEN)
     buf[i++] = incomingChar;
  char* arg1 = subStr(buf, ",", 1);
  char* arg2 = subStr(buf, ",", 2);
  Serial.print(buf);
  Serial.print(" got: ");
  Serial.print(arg1);
  Serial.print(" and ");
  Serial.println(arg2);
char* subStr (char* str, char *delim, int index) {
   char *act, *sub, *ptr;
   static char copy[SERIAL_BUFFER_SIZE];
   int i;
   strcpy(copy, str);
   for (i = 1, act = copy; i <= index; i++, act = NULL) {
      //Serial.print(".");
      sub = strtok_r(act, delim, &ptr);
      if (sub == NULL) break;
   return sub;
Arduino B code: (reads an analog input and sends it over I2C to Arduino A every 2 secs)
#include <Wire.h>
#define LocalAddress 0x9
#define RemoteAddress 0x8
#define BUF_LEN   128
int i;
char incomingChar, buf[BUF_LEN];
// Define sensor
const int analogInPin = 3;
int sensorValue = 0;
int outputValue = 0;
//Define timings
unsigned long previousMillis;
unsigned long interval = 2000;
  if (millis() - previousMillis > interval) {
    previousMillis = millis();
    printReading();
void printReading(){
   Wire.beginTransmission(RemoteAddress);
   sensorValue = analogRead(analogInPin);
   outputValue = map(sensorValue, 0, 1023, 0, 255);
      // Only for debugging
      Serial.print(sensorValue);
      Serial.print(",");
      Serial.print(outputValue);
      Serial.print("\n");
      Wire.send(sensorValue);
      Wire.send(",");
      Wire.send(outputValue);
      Wire.send("\n");
      Wire.endTransmission();
Now the problem is that i only get strange characters on Arduino A's serial monitor. Could somebody please have a look and tell me where i made a mistake?
Output on Arduino B serial: 844,211
Output on Arduino A serial: ), got: ) and J
Thanks in advance,
EriSan500
You are sending ints and receiving strings. Where did you expect the conversion to take place?
Thanks PaulS,
itoa() did the trick :wink:
