I'm having a lot of trouble with my LCD. It is the LCD I linked to below and when powered up I get the standard boot screen that it shipped with but it does not accept any commands from the Arduino.
I've tried it with the SDA SCL connections reversed and everything. Jumper, no jumper, everything.
The only reason I'm asking here is I've contacted them twice this week with no answer. >:(
I would also add a 3K3 pull up resistor on each I2C line.
Even though the arduino supposedly uses internal pullups on analog 4 and 5 when you use I2C? My only I2C experience is with an RTC, which worked with and without external pullup resistors. (I had them in the circuit since many I2C examples show them, but then removed them after I read about the internal resistors.) Would there be different cases when you would or wouldn't add external pullup resistors, or is it a case by case, trial and error thing?
Yes the internal pull ups are only about 10K. If you look at the signals on an oscilloscope without external pull ups it looks very bad. Yes it still works, but for the sake of two resistors you are throwing away so much margin.
How does one calculate the "right" value for the pull-up resistors?
You look in the data sheet of the device you are using. It will either give a pull up resistor in the AC operating conditions, or give a current required for the pull down and you can work out the resistor from the voltage rail you are using.
(In many schematics I saw 10K.)
Yes but that doesn't mean it's right, there is a lot of rubbish circuits on the internet.
The other thing to do is to look at the rise time of the signals on an oscilloscope. If the pull up is too high this rise time will be too slow.
Kylej
Check the address of your I2C device some addresses include the read / write bit others do not. I would try an address of 0x26. Also check the wring on any external address pins.
I never got a reply from the company, go customer service, but I figured out the problem. After upgrading to 0017 and burning a new bootloader I was able to get the LCD working. I wrote a quick program to give me the results from a light sensor and while playing with it opened it in 0016 to upload it. My raw and calculated input values displayed but none of the text I was sending to it.
Works fine now even without the pull-up resistors. Display works great, albiet a little slow, but I won't be buying from them again.
There is a specific library for the web4robots i2c lcd display.
It has all the extended features covered as well.
Works well.
I cant comment on the customer services but the lcd controller seems a good bit of kit and the library produced by Dale, dwentz on this forum is easy to use.
I'll end up using the external resistors anyway as a just in case.
The library you linked to is the one I'm using, I honestly have no idea why I was having so much trouble with this thing. It was discouraging to say the least.
Do external pull-ups affect speed of I2C communications at all? I've had it running successfully at 300KHz with no external pull-ups, but that was over a 4-inch run of wire.
