I2C EEPROM size
Writing to an external I2C EEPROM 24C512 works fine for the first 4095 bytes.
When I write to address 4096, and then read from this address the value is OK, but at the same time data is changed at address 0. I think this chip has 65536 bytes of space, but it behaves as if it's capacity is only 4096 bytes.
The code:
#include <Wire.h>
#define disk1 0x50    //Address of 24LC256 eeprom chip
int deviceaddress;
void setup(void)
  Wire.begin();
  deviceaddress = disk1;
  for (int i = 0; i < 10; i++) { writeEEPROM(i, 3); }
  for (int i = 4090; i < 4100; i++) { writeEEPROM(i, 3); }
  writeEEPROM(4096, 0);
    Serial.print(i);
    Serial.print("\t");
    Serial.println(readEEPROM(i), DEC);
    Serial.print(i);
    Serial.print("\t");
void loop(){}
void writeEEPROM(unsigned int eeaddress, byte data )
  Wire.beginTransmission(deviceaddress);
  Wire.write((int)(eeaddress >> 8));   // MSB
  Wire.write((int)(eeaddress & 0xFF)); // LSB
  Wire.write(data);
  Wire.endTransmission();
  delay(5);
byte readEEPROM(unsigned int eeaddress )
  byte rdata = 0xFF;
  Wire.requestFrom(deviceaddress,1);
  if (Wire.available()) rdata = Wire.read();
  return rdata;
Serial output:
|0|0|
|1|3|
|2|3|
|3|3|
|4|3|
|5|3|
|6|3|
|7|3|
|8|3|
|9|3|
|4090|3|
|4091|3|
|4092|3|
|4093|3|
|4094|3|
|4095|3|
|4096|0|
|4097|3|
|4098|3|
|4099|3|
I tested several 24C512, they all give the same result.
I don't know, am I doing something wrong, or are this EEPROMS really only 4096 in size, when they should be 65536.
You write 0 to 4096, you read 0 from 4096, what is the problem?
Writing a zero to 4096 causes that a read at 0 returns a zero.
Try an example of a working library: https://github.com/RobTillaart/I2C_EEPROM.
That library can write many bytes at once, and takes care of the pages that the EEPROM uses internally. That makes it more complex.
I tried without a library, as in the example above, I tried with libraries "I2C_EEPROM.h", and "AT24C512C.h", but the result is always the same. I only need to write one byte at a time.
When I write to address 4096, the value at address 0 is also changed, and I don't want this.
There could be a bug in both libraries (that would be weird), or your EEPROM is damaged, or something else.
Did you try the examples that came with those libraries ?
Do you have an other EEPROM ?
I tried the examples from both libraries, and they work.
I tried with several 24C512, and 24LC256. The result is the same.
That's why I came here :slight_smile:
@lukc
1. This is (Fig-1) the conceptual organizational diagram of AT24C512 EEPROM.
eeprom512X
Figure-1:
2. The EEPROM has the capacity of holding 512 kbits (512x1024) data. This means that there are 512x1024 memory cells inside the EEPROM. Each cell can hold 1-bit data.
3. The cells of the EEPROM are organized as memory locations; where, each memory location can hold 8-bit data (byte). Thus, there are (512x1024)/8 = 65536 memory locations in the EEPROM.
4. Every memory location has a 16-bit address. Thus, the address of the bottom location is 0 in decimal-base (0x0000 in hex-base). The addres of the top location is 65535 in decimal-base (0xFFFF in hex-base).
5. The address of the target location into which we wish to perfrom data read/write operation is 4096 in decimal-base (0x1000 in hex-base).
6. Check that the EEPROM is connected with UNO as per following diagram (Fig-2).
eeprom512y
Figure-2:
7. Let us upload the following (tested) sketch to write 0x23 into location 4096 (0x1000) and read back.
#include<Wire.h>
  Wire.begin();
  //-- writing process----
  int memAddress = 0x1000;
  Wire.beginTransmission(0x50);  //EEPROM I2C address
  Wire.write(highByte(memAddress));  //pointing/queueing memory address
  Wire.write(lowByte(memAddress));  //pointing/queueing memory address
  Wire.write(0x23);                  //queueing data byte in buffer
  delay(5); //write cycle delay
  //----reading back--------------------
  Wire.requestFrom(0x50, 1); //reading 1-byte from location 0x1000 (4096)
  byte y = Wire.read();
  Serial.println(y, HEX);   //check that Serial Monitor shows: 23
8. Now write 0x67 into location 0 (0x0000), read it back, and also read from location 4096 (0x1000). Check that the data are different.
9. Now do the experiment with the sketch of your Post-1.
I have executed your sketch of Post-1, and I see that the Location-0 still holds 3 though data of Location-4096 was chaned from 3 to 0.
0	3
1	3
2	3
3	3
4	3
5	3
6	3
7	3
8	3
9	3
4090	3
4091	3
4092	3
4093	3
4094	3
4095	3
4096	0
4097	3
4098	3
4099	3
Location-0 holds: 3
Thank you all for your time. My eeprom was already on a breadboard with 2 more I2C devices, and other things, when I encountered this problem.
Now I tested with only eeprom on the breadboard, and it works correct.
So now I know my eeprom chips are ok, and I know where too look for the problem.
This problem was caused by DS1307. I replaced it with DS3231, and all works fine :slight_smile:
