i2c flashing lights HELP!!
Hello,
I have hooked up 2 Arduino Uno's to a button panel and DMD.
The Master controls buttons and displays values (increasing by 1's like a counter) on the DMD depending on which button is pressed.
I would like the Slave to know when a specific button is pressed, then flash an LED as the numbers on the DMD change.
Currently, i have it so when a button is pressed, a corresponding LED (hooked up to the Slave) stays on when the others flash off.
Example: LED's are on in standby...When button 1 is pressed, the DMD counts from 0-25. After 25 is reached, THEN LED's 2, 3, and 4 flash off while LED 1 stays on. All 4 LED's then return to an ON state.
see the video for reference:
What i would like to happen is as follows:
LED's are on in standby...when button 1 is pressed, the DMD counts from 0-25, and only LED 1 flashes on then off with every number change on the DMD. After the DMD reaches 25, all 4 LED's then turn back on.
Here is the Master Code:
#include <SD.h>
#include "SPI.h"
#include "DMD.h"
#include "TimerOne.h"
#include "Arial_black_16.h"
#include <Wire.h>
const int buttonPin = 2;
int buttonState = 0;
int L1 = 14;
int L2 = 15;
int L3 = 16;
int L4 = 17;
int score;
int totalscore;
int rep1;
int rep2;
int rep3;
int rep4;
int flash1;
//Fire up the DMD library as dmd
#define DISPLAYS_ACROSS 1
#define DISPLAYS_DOWN 1
DMD dmd(DISPLAYS_ACROSS, DISPLAYS_DOWN);
void ScanDMD()
  dmd.scanDisplayBySPI();
const byte PanelWidth = 32;
const byte MaxStringLength = 5;
char CharBuf[MaxStringLength + 1];
// the setup routine runs once when you press reset:
  pinMode(buttonPin, INPUT);
  pinMode(L1, INPUT_PULLUP);
  pinMode(L2, INPUT_PULLUP);
  pinMode(L3, INPUT_PULLUP);
  pinMode(L4, INPUT_PULLUP);
    //initialize TimerOne's interrupt/CPU usage used to scan and refresh the display
  Timer1.initialize( 5000 );          //period in microseconds to call ScanDMD. Anything longer than 5000 (5ms) and you can see flicker.
  Timer1.attachInterrupt( ScanDMD );  //attach the Timer1 interrupt to ScanDMD which goes to dmd.scanDisplayBySPI()
  dmd.selectFont(Arial_Black_16);
  Wire.begin();
byte x = 0;
byte y = 0;
byte z = 0;
byte zz = 0;
  Wire.beginTransmission(8); // transmit to device #8
  Wire.write(x);              // sends one byte
  Wire.write(y);              // sends one byte
  Wire.write(z);              // sends one byte
  Wire.write(zz);              // sends one byte
  Wire.endTransmission();    // stop transmitting
   buttonState = digitalRead(buttonPin);
  int light1 = analogRead(L1);
  int light2 = analogRead(L2);
  int light3 = analogRead(L3);
  int light4 = analogRead(L4);
    String displayString = String(totalscore);
    center_theDisplay(displayString); delay(80);
    Serial.println (totalscore);
  x = light1;
  y = light2;
  z = light3;
  zz = light4;
if ((x < 200) && (rep1 < 50)){
      for(int score = totalscore ; score < (totalscore+25); score++){
        delay (16);
         displayString = score;
         center_theDisplay(displayString); delay(16);
        Serial.println (score);
        rep1 = rep1 + 1;
    totalscore = totalscore + 25;
if ((y < 200) && (rep2 < 100)){
      for(int score = totalscore ; score < (totalscore+50); score++){
        delay (16);
        rep2 = rep2 + 1;
    totalscore = totalscore + 50;
if ((z < 200) && (rep3 < 150)){
      for(int score = totalscore ; score < (totalscore+75); score++){
        delay (16);
        rep3 = rep3 + 1;
    totalscore = totalscore + 75;
if ((zz < 200) && (rep4 < 200)){
      for(int score = totalscore ; score < (totalscore+100); score++){
        delay (16);
        rep4 = rep4 + 1;
    totalscore = totalscore + 100;
  delay(5);
void center_theDisplay(String input_Str) {
  byte charCount, total_charWidth, x_position;
  input_Str.toCharArray(CharBuf, MaxStringLength + 1); //string to char array
  charCount=  input_Str.length();
  if (charCount==0) exit;
  total_charWidth= 0;
  for (byte thisChar = 0; thisChar <charCount; thisChar++) {
    total_charWidth= total_charWidth + dmd.charWidth(CharBuf[thisChar]) +1; //add 1 pixel for space
  total_charWidth= total_charWidth -1; //no space for last letter
  x_position= (PanelWidth - total_charWidth) /2; //position(x) of first letter
  // output the string to the DMD Panel
 dmd.drawString( x_position, 1, CharBuf,charCount, GRAPHICS_NORMAL);
if (buttonState == HIGH){
    dmd.clearScreen(true);
    totalscore = 0;
    rep1 = 0;
    rep2 = 0;
    rep3 = 0;
    rep4 = 0;
Here is the SLAVE Code:
#include <Wire.h>
  Wire.begin(8);                // join i2c bus with address #8
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(9600);           // start serial for output
  pinMode(2, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  delay(10);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany) {
  int x = Wire.read();    // receive byte as an integer
  int y = Wire.read();    // receive byte as an integer
  int z = Wire.read();    // receive byte as an integer
  int zz = Wire.read();    // receive byte as an integer
  digitalWrite(2, HIGH);
  digitalWrite(5, HIGH);
  digitalWrite(8, HIGH);
  digitalWrite(9, HIGH);
if (x < 200){
  digitalWrite(5, LOW);
  digitalWrite(8, LOW);
  digitalWrite(9, LOW);
if (y < 200){
  digitalWrite(2, LOW);
if (z < 200){
if (zz < 200){
  Serial.print(x);         // print the integer
  Serial.print(";");         // print the integer
  Serial.print(y);         // print the integer
  Serial.print(z);         // print the integer
  Serial.print(zz);         // print the integer
  Serial.println(" ");         // print the integer
there might be some random code in there left over from testing different things...if you have any suggestions on making things more concise, it would be greatly appreciated as well =)
Please let me know if you have any questions or concerns.
Thanks,
Kirk
