Thank you for the reply Wawa.
Just for further clarity, I am using a INA219 High Side DC Current Sensor Breakout - 26V ±3.2A Max [STEMMA QT] : ID 904 : $9.95 : Adafruit Industries, Unique & fun DIY electronics and kits as the board.
Regarding your suggestion, I put a load on the circuit and took some readings with the INA219 and also with an accurate multimeter.
I placed the meter in series with the shunt and with the load I had on it, it measured at 1.71A, whereas the INA219 showed 5.5mA. Whilst in theory I should be able to multiply this by 400, this ends up being 2.2A.
I then took a voltage reading across the shunt which showed 0.41mV, whereas the INA219 showed 0.56mV.
Heres the code I'm running:
#include <Wire.h>
#include <Adafruit_INA219.h>
Adafruit_INA219 ina219;
void setup(void)
while (!Serial) {
// will pause Zero, Leonardo, etc until serial console opens
delay(1);
uint32_t currentFrequency;
Serial.println("Hello!");
// Initialize the INA219.
// By default the initialization will use the largest range (32V, 2A). However
// you can call a setCalibration function to change this range (see comments).
ina219.begin();
// To use a slightly lower 32V, 1A range (higher precision on amps):
//ina219.setCalibration_32V_1A();
// Or to use a lower 16V, 400mA range (higher precision on volts and amps):
//ina219.setCalibration_16V_400mA();
Serial.println("Measuring voltage and current with INA219 ...");
void loop(void)
float shuntvoltage = 0;
float busvoltage = 0;
float current_mA = 0;
float loadvoltage = 0;
float power_mW = 0;
shuntvoltage = ina219.getShuntVoltage_mV();
busvoltage = ina219.getBusVoltage_V();
current_mA = ina219.getCurrent_mA();
power_mW = ina219.getPower_mW();
loadvoltage = busvoltage + (shuntvoltage / 1000);
Serial.print("Bus Voltage: "); Serial.print(busvoltage); Serial.println(" V");
Serial.print("Shunt Voltage: "); Serial.print(shuntvoltage); Serial.println(" mV");
Serial.print("Load Voltage: "); Serial.print(loadvoltage); Serial.println(" V");
Serial.print("Current: "); Serial.print(current_mA); Serial.println(" mA");
Serial.print("Power: "); Serial.print(power_mW); Serial.println(" mW");
Serial.println("");
delay(2000);
From what I understand, there are adjustments in the library that need to be made for the different shunt. There are some embedded steps however I tried following these without any luck.
I think that the PGA gain can be adjusted in the library, however I am just unsure how to do it.
Any assistance would be of great assistance.
Adafruit_INA219.cpp (17.6 KB)
Adafruit_INA219.h (9.39 KB)
