I have a weird (to me) problem trying to get I2C working between two arduinos.
I'm using the master_reader and slave_sender example sketches on a Duemilonove and a Diecimila (tried both as master) They're connected only on a4 and a5
The behavior I'm seeing:
When both boards are powered via USB everything works as normal.
When the slave board is powered via 9v battery, it doesn't send anything
When the slave board is powered via a 9v wall wart, it sends gibberish: "ûÿÿÿÿ"
I've tried adding 1k pullup resistors to the data lines, but that hasn't had any effect.
Any ideas?
