I tried this library and it does the same thing. I have the SDA on D Pin 0 (Pin1) and SCL on D Pin 1 (Pin 2). It does not find the Display when scanning the pins.
Console Output
Scanning ...
8-bit 7-bit addr
No I2C device found.
Done
Sketch
// Scan I2C bus for device responses
#define SDA_PORT PORTD
#define SDA_PIN 0
#define SCL_PORT PORTD
#define SCL_PIN 1
#define I2C_TIMEOUT 100
#define I2C_NOINTERRUPT 0
#define I2C_SLOWMODE 0
#define FAC 1
#define I2C_CPUFREQ (F_CPU/FAC)
/* Corresponds to A4/A5 - the hardware I2C pins on Arduinos
#define SDA_PORT PORTC
#define SDA_PIN 4
#define SCL_PORT PORTC
#define SCL_PIN 5
#define I2C_FASTMODE 1
#include <SoftI2CMaster.h>
#include <avr/io.h>
void CPUSlowDown(int fac) {
// slow down processor by a fac
CLKPR = _BV(CLKPCE);
CLKPR = _BV(CLKPS1) | _BV(CLKPS0);
void setup(void) {
#if FAC != 1
CPUSlowDown(FAC);
#endif
Serial.begin(9600); // change baudrate to 2400 on terminal when low CPU freq!
Serial.println(F("Intializing ..."));
Serial.print("I2C delay counter: ");
Serial.println(I2C_DELAY_COUNTER);
if (!i2c_init())
Serial.println(F("Initialization error. SDA or SCL are low"));
Serial.println(F("...done"));
void loop(void)
uint8_t add = 0;
int found = false;
Serial.println("Scanning ...");
Serial.println(" 8-bit 7-bit addr");
// try read
do {
if (i2c_start(add | I2C_READ)) {
found = true;
i2c_read(true);
i2c_stop();
Serial.print("Read: 0x");
if (add < 0x0F) Serial.print(0, HEX);
Serial.print(add+I2C_READ, HEX);
Serial.print(" 0x");
if (add>>1 < 0x0F) Serial.print(0, HEX);
Serial.println(add>>1, HEX);
} else i2c_stop();
add += 2;
} while (add);
// try write
add = 0;
do {
if (i2c_start(add | I2C_WRITE)) {
found = true;
i2c_stop();
Serial.print("Write: 0x");
Serial.print(add+I2C_WRITE, HEX);
} else i2c_stop();
i2c_stop();
add += 2;
} while (add);
if (!found) Serial.println(F("No I2C device found."));
Serial.println("Done\n\n");
delay(1000/FAC);
