Success, the cursor position is line,column and on a 16x2 the lines are 1 and 2:
delay(800);
Wire.begin();
//pinMode(ledPin, OUTPUT); // sets the digital pin as output
lcd.setType(LcdAddr,2,16); // Define rows and columns for LCD
lcd.clear(LcdAddr);
lcd.backLight(LcdAddr,60);
lcd.setCursor(LcdAddr,1,3);
lcd.print(LcdAddr," HobbyTronics"); // Print a message to the LCD.
lcd.setCursor(LcdAddr,2,1);
lcd.print(LcdAddr,"Line 2 ?");
Many thanks everyone. I've learned a lot there.
I will have a bit of a play with this lcd and i2c module but I think I will find a more standard one for the project I'm trying to build.
@scubascooby
Glad the display is working. At least the backpack is not going to waste.
You can easy build your own "backpack" by just using a PCF8574. The PCF8574 need pullup resistors at the output of the chip. I build my own and I have a test code. I just simply follow the datasheet of the LCD display and the datasheet of the PCF8574.
Here my code
#include <Wire.h>
byte device_address = 0x20; // I connect the A0, A1, A2 to GND I2C address of the PCF8574
byte data_out;
byte RS_pin = 2;
byte E_pin = 3;
const unsigned int enable_signal = 1500; // E pin pulse for 1.5 millisecond duration
char message[11]="HELLO WORLD";
pinMode(RS_pin, OUTPUT);
pinMode(E_pin, OUTPUT);
digitalWrite(RS_pin, LOW);
digitalWrite(E_pin, LOW);
Wire.begin();
data_out = B00111000; // Set the display for 8 bits mode, 2 line
Wire.beginTransmission(device_address);
Wire.write(data_out);
Wire.endTransmission();
digitalWrite(E_pin, HIGH);
delayMicroseconds(enable_signal);
data_out = B00001111; // cursor setting
data_out = B00000001; // clear the display
data_out = B10000000; // set the display data address location
digitalWrite(RS_pin, HIGH);
for (int x=0;x<11;x++)
Wire.write(message[x]);
delay(200);
delay(3000);
The trick is .... you first setup the RS pin of the LCD ( register select) 0 for command 1 for data to be display. Second, you send the data ( command or data to be display ) and you set the E pin for a few millisecond ( create a pulse ). Repeat the procedure for sending a command / display data.
I'm trying to avoid as much low level electronics as possible. I want Lego not Papier mache
I want to build a functional, robust, diver-proof trimix analyser so there will be a lot of work in the structural parts to keep me busy.
