Hello, I have a question regarding pull ups for I2C:
- My BMP180 in GY-68 board has 4.7k ohm pull ups for both SCL and SDA lines. While using Wire library I noticed that pull ups present in ATmega are also activated.
Standalone BMP180 works with my Leonardo, but after connecting it with other peripherals, something caused a serious freeze. May this double set of pull ups have influenced the malfunction?
- If I connect another I2C device like RTC DS1307 also equipped with its own pull up set of 2 x 3.3 k ohm.
Is it possible that it - together with BMP180 (with another resistors) might not work properly?
